Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 131
Thread: Overheating with TD05 turbochargers
  1. #51
    I don't bite
    Southern IN
    I would do gtwizards trick plus an extractor vent in hood behind radiator. You'll get more air in and out. A properly placed vent can actually pull air out.
  2. #52
    Apr 2011
    on and off since 05
    Romulus
    Has anyone tried not running thermostat? I am having similar problems hot wired my fans add a third pushing on drivers side remove bumps on the stock hood. Still overheated today with no air. New waterpump new radiator leak tested system no issue with cooling system that I can find. I even heat reflective wrapped my radiator hose and intercooler pipe to stop heat transfer. I am getting stressed and worried about ruining a set of heads.
    Nathaniel Colton Orr Born 12/23/2011 6lbs 13oz, 20 inches healthy as can be for being early!!!!!!!!!
    BEST EARLY CHRISTMAS PRESENT EVER A SON!!!!!!!!!!!!!!!!!!!!!!!
    92 Stealth TT R/T
    Mods: t30 ball bearing turbos, IPS FMIC, AEM V2.0 standalone, Tial BOV, Ksport struts, Tublar upper rear control arms, VOLKS 18 inch 2 piece wheels, AEM Wideband O2, AEM True Boost, 780 injector, IPS fuel rails, AEROMOTIVE FPR, FM Oil cooler, RPS Flywheel, Kevlar timing belt, hose candy silcone lines and fittings, krank vent system, single pass 3sx radiator soon as I finish getting all parts installed in trans, 6 speed trans with dog box and Torison Diff ,and Kaaz rear diff
  3. #53
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Put a pressure gauge on your coolant system propbreaker. If you see the preesure spike above your cap crackopen pressure your pushing coolant past the heads and risking damaging them. Its a good failsafe in the 6xX and up range.
    BTW, congrats on the little one and welcome back! We had our second boy this past Dec also. He was born on the 26th. His name is Landon Reid. Kids are awesome! Bring out the best in you!
  4. #54
    Known as SLGuy
    Owens Cross Roads, AL
    Quote Originally Posted by propbreaker View Post
    Also check out your thermostat housing cap. If its old, you might consider replacing it. Mine was cracked and pushing coolant out into the reservoir, which introduced air pockets.
  5. #55
    Apr 2011
    on and off since 05
    Romulus
    I tested coolant pressure today no spikes. As for the housing it is as new as you can get it has the 3sx kit for water ani coolant lines no cracks I had it powder coated made sure everything clear. I am going pull thermostat temp test it and most likely replace it.
  6. #56
    - O - SIX -
    Colorado, USA
    Start it cold and leave the rad cap off and let it idle for 10 mins or so. See if it bubbles or starts to lift coolant.
  7. #57
    Known as SLGuy
    and get one of these
    Lisle LI24610 - Lisle Spill-Free Coolant Funnels - Overview - SummitRacing.com
    They work great!
  8. #58
    Apr 2011
    on and off since 05
    Romulus
    I think I figured it out it was not even the cooling system it was the front hot pipe for intercooler. It was touching exhaust manifold just so slightly and it was transferring the heat to upper rad hose heating the water faster. I am waiting for wife to get off if work so I can drive. Since I spent most of the day taking care of rehabbing the pipe to clear.
    Thank jfast for welcoming me back
  9. #59
    Known as SLGuy
    Cramped engine bays. Mine sits verrrry close to my exhaust manifold, but I can see just the most tiny bit of air between the pipe and exhaust manifold.
  10. #60
    Apr 2011
    on and off since 05
    Romulus
    Well that did not solve it. It idled without overheating for 45mins and stayed below half on the gauge. I barely went around the block and the heat shot up. I am stumped I can see it circulating and fans blow correct direction. No coolant leaking or milky oil no smoke. I am annoyed. Car is toward rich on the tune and timing is retard so I am out of ideas
