Just putting my engine back in after months on the bench. Noticed that the diameter of the flange bolt (9mm) that I took out of the front mounting is a whole lot smaller than the diameter of the sleeve (16mm) in the rubber mounting itself. I was just about to by a new mounting because I thought I'd lost an insert or something. Isn't this bolt supposed to be tight fit in the sleeve? The engine roll bracket holes are right but that steel sleeve in the engine mount is 7mm larger than the bolt.
The mount is in otherwise excellent condition and all the illustrations I look at don't indicate I'm missing anything but just doesn't seem right that the gap between the bolt and sleeve should be that large?
Advice anyone, please? THX.
