Page 69 of 154 FirstFirst ... 1959676869707179119 ... LastLast
Results 681 to 690 of 1538
  1. #681
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    So any updates? I see the v2.24 has support for 0-150psi oil pressure gauge. Would that work in slot A?
  2. #682
    Quote Originally Posted by NickS VR4 View Post
    The Oil Pressure Gauge, AEM EGT Gauge, and Water/Alchy injection control are all hacks. The LCD boostcontroller was never designed for these, but when someone requests these things to the existing hardware I find a way.
    Currently I'm experimenting with bluetooth, and SD card datalogging options again.
  3. The Following 2 Users Say Thank You to BlackStealth For This Useful Post:
  4. #683
    Feb 2012
    Westbury, NY
    ...and what a great hack it is. I'm currently using a Zeitronix oil pressure sending unit and with the "custom" tap I made with [BlackStealth] help I pulled it off without a glitch.
  5. #684
    Dad verified
    NJ
    Any chance we can get an alert feature that will flash the backlight red if certain values go out of range in addition to the buzzer?
  6. #685
    I am not on the newest update, but mine does flash red when over boosting, and the knock threshold is reached.
  7. #686
    Hey, Bill, I'm not gonna get started on my install for a few weeks (vacation, etc.) but I was wondering where you went through the firewall with the solenoid wires and vac-line?
    I still have to line up an instrument cluster to cut up and all, but I'm collecting info...
  8. #687
    I went through the passenger side under glove box in the existing hole. I will have to drill/grommet another hole if I need to add anything further though.
  9. #688
    Hmm.
    We need Hans or someone with a bunch of extra material to find a place to punch a dedicated hole for add-ons...
  10. #689
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Alright I have a question for ya. I'm having some issues logging using Evoscan. I copied the settings you posted and sometimes it works well and other times it tells me I'm not using a compatible cable (suggests I may be using the 2.0 cable when I am using FTDI). It seems like a bad connection though because it is hit or miss whether it connects and sometimes it will connect then I pull out to begin a pull and it will end the log. Should I try a new cable?
  11. #690
    Dad verified
    NJ
    Disregard my request than. I didn't have it hooked up yet, just didn't recall reading about that feature.
    With that said, Great Feature
  • History
  • Information
  • Groups
  • Events
  • Resources
