So any updates? I see the v2.24 has support for 0-150psi oil pressure gauge. Would that work in slot A?
The Oil Pressure Gauge, AEM EGT Gauge, and Water/Alchy injection control are all hacks. The LCD boostcontroller was never designed for these, but when someone requests these things to the existing hardware I find a way.
Currently I'm experimenting with bluetooth, and SD card datalogging options again.
Any chance we can get an alert feature that will flash the backlight red if certain values go out of range in addition to the buzzer?
I am not on the newest update, but mine does flash red when over boosting, and the knock threshold is reached.
Hey, Bill, I'm not gonna get started on my install for a few weeks (vacation, etc.) but I was wondering where you went through the firewall with the solenoid wires and vac-line?
I still have to line up an instrument cluster to cut up and all, but I'm collecting info...![]()
I went through the passenger side under glove box in the existing hole. I will have to drill/grommet another hole if I need to add anything further though.![]()
Alright I have a question for ya. I'm having some issues logging using Evoscan. I copied the settings you posted and sometimes it works well and other times it tells me I'm not using a compatible cable (suggests I may be using the 2.0 cable when I am using FTDI). It seems like a bad connection though because it is hit or miss whether it connects and sometimes it will connect then I pull out to begin a pull and it will end the log. Should I try a new cable?
