Page 204 of 892 FirstFirst ... 104154194202203204205206214254304704 ... LastLast
Results 2,031 to 2,040 of 8916
  1. #2031
    MrSinister
    Guest
    After months of shopping, finally went out and bought one.
  2. The Following User Says Thank You to MrSinister For This Useful Post:
  3. #2032
    Jan 2011
    az
    Quote Originally Posted by MrSinister View Post
    shes a beauty
  4. #2033
    Man vs 3/S verified
    Kingston, WA
    What year?
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  5. #2034
    SoSoCal verified
    the 95 base got new brake overhaul , new rotors new calipers, new pads, ss braided lines and speed bleeders
  6. #2035
    Sounds like the day I had with my TSI several years ago. I was replacing the engine due to massive blow by, and trans at the same time because of a broken/bent 3/4 shift rail. I wanted to replace the lightweight flywheel with the one that came with the engine. I bolted my clutch to the flywheel, then started sliding the "new" AWD trans on only to realize it was a FWD flywheel, which is bigger and therefor the trans wouldnt fit. I slid it all back apart, took my clutch off, swapped the flywheel, bolted my clutch back on, slid it all together, started bolting it up only to realize the friggin backing plate was different. I had to take the trans back off, the clutch back off, the flywheel back off, just to swap the backing plate. That day SUCKED.
    That sounds like when I did the AWD conversion engine build. lol
    The only reason I'm feeling like a pussy about this is I remember talking to you on the other site one night when you were having issues. I think you pulled the trans 3-4 times that night. ha ha
    94 3500gt vr2? verified
    NC
    What year?
    I'm guessing 97
  8. #2037
    Got the exhaust mani welded up, installed, and everything put back together.
  9. #2038
    MrSinister
    Guest
    Quote Originally Posted by n2nsanity View Post
    I'm guessing 97
    97'. Stock (except for sound system). 68K
  10. #2039
    JNS Engineering verified
    San Jose, CA
    Quote Originally Posted by DuTTch View Post
    My Spyder got SS lines, new pads, turned rotors, and rebuilt calipers
  11. #2040
    Man vs 3/S verified
    Kingston, WA
    What pads did you get?
    Chad, NICE!!
