Page 203 of 892 FirstFirst ... 103153193201202203204205213253303703 ... LastLast
Results 2,021 to 2,030 of 8916
  1. #2021
    Quote Originally Posted by DK77 View Post
    That's what I suspected. Would I be ok with installing the wideband and retuning it prior to re-ringing or would I be better off doing what I said and essentially reverting to the stock tune?
    if you can get it tuned ok before rebuilding that would be fine.
  2. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  3. #2022
    Feb 2011
    Scottsbluff, NE
    Ok, thanks for the input.
  4. #2023
    One fix at a time verified
    Kansas
    I started to pull the downpipe to swap in a 3.5" high flow cat but only had an hour to work on it so I only got it pulled off. I noticed I had a leak at the rear 02 housing so I'm going to beat my flange a little to square it up.
  5. #2024
    RTBOOST verified
    Florence, Wisconsin
    I bought various things for it to keep things rolling with the transmission overhaul and general rebuilding process of the car...One perk of not currently having a g/f, haha!
  6. #2025
    Absolutely nothing. Didn't even look at it.
  7. #2026
    Trans is back in and replaced the polly swaybar bushings with some tighter ones. Now back to work!
    Pueblo, CO
    adjusted my cruise control pedal adjustment, rethreaded the clutch adjustment bolt and putting in the billet tcase tonight. yay
  9. #2028
    cancel that, didn't put the stupid plate on so now I have to pull the trans, clutch and flywheel. When I realized what I did I felt like my dog got hit by a car. So today was totally fucking wasted. I'm back to square one, actually I'm behind because I haven't pulled the clutch and flywheel. I'm seriously pissed and disheartened! Not sure why, I've done dumb shit before but this time I really just want to shoot holes in the car. Maybe because the trans went in easier than any trans I've ever done. With the luck I've had lately I might just shoot the damn thing.
  10. #2029
    West MI
    Put the brackets back on the engine and started changing valve stem seals
  11. #2030
    Sounds like the day I had with my TSI several years ago. I was replacing the engine due to massive blow by, and trans at the same time because of a broken/bent 3/4 shift rail. I wanted to replace the lightweight flywheel with the one that came with the engine. I bolted my clutch to the flywheel, then started sliding the "new" AWD trans on only to realize it was a FWD flywheel, which is bigger and therefor the trans wouldnt fit. I slid it all back apart, took my clutch off, swapped the flywheel, bolted my clutch back on, slid it all together, started bolting it up only to realize the friggin backing plate was different. I had to take the trans back off, the clutch back off, the flywheel back off, just to swap the backing plate. That day SUCKED.
