Results 1 to 7 of 7
Thread: I Need INFO On FIAV Delete
    Quote Originally Posted by DarK_sTyLe View Post
    thankz guys for fast response,,,
    can a damaged FIAV cause a high idle when cold about 2000-3000 RPM...
    everything else checked an working fine(BISS,IAC,TPS)
    Yes it can. Over time the spring can become loose or damaged. Another thing that can cause this is leaking o-rings in the throttle body plate, but other symptoms tend to follow it (slight vacuum/boost leak).
    thankzz i think thats what am going to do,, replace my TB with a working one and replace o-rings too
