If you've got a EGT what do you see cruising down the free way?
I see 650-700 at about 3k RPM doing 80 in 5th.
I'm just curious to see if thats in the normal ranges.
Everyone will also need to state where their EGT probe is located. Some are before and some are after. Front or rear bank? Also F or C?
Mine is after the turbo on the rear bank. Choose after the turbo as it anything on it breaks it doesn't Fubar my turbo.
I think I'm about 750-800F 80mph 5th gear. But i'm also 10:1 TT so mine is going to be a little higher
Full out pull at 14psi, 93oct and 30/70 meth/water up to 6k I never get over 950F
I've never heard of an EGT probe breaking off and flying through a turbine. The temperature after the turbo is a function of how much work the turbo is taking out of the exhaust stream, so it's not going to be as readily useful for tuning purposes... Not to say EGT probes are all that useful for tuning anyway... But if you're going to put the EGT probe post-turbine, you might as well not have it.
front, before turbo. cruzing = 1000 F, WOT = 1500F, idle = 600F
I'm 98% sure of accuracy info above. sometimes I just forget...![]()
700 cruising, same as yours, Alan. If I do a 3rd/4th/5th pull to 130 or so its up to about 950. Mine is placed in the front manifold where the 3 meet.
Cruising up a hill at 2500 with 0-3 PSI it will be around 825. cruising downhill it goes way down, 300 if the hill is long enough.
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
If the probe were to melt and break off it would fubar the turbo. Granted the probes are now in a SS sleeve, that chance is still there. The temp reading difference of running the Probe after the turbo is 200-300 degrees what it would be at the head.
The ones I originally posted are my straight numbers. I am used to compensating for the location of the probe in my head. I'm updating my numbers in the first thread with the compensated numbers.
On a side note I am awaiting a second probe that will be installed before the turbo so I have absolute comparison numbers. Most likely won't be till next year as the Stealth is down for the winter now.![]()
Front header. 6-700C at cruise, just over 1000C when pushing the car![]()
