Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Normal EGT reading
    Maybe it's because I am 10:1.
    All sensors were replaced during my build so nothing funny there to worry about.
    For me a full out pull at 14psi, 93oct and 30/70 meth/water (315ml nozzle) & I never get over 950F/510C and my WB is 12.0-11.5.
    I'll need to wait till my second EGT probe gets in and see what the temp is pre-turbo. Cause if all my other gauges are within a good range and I should be at about 1800F/950C then that almost 900F the turbos as soaking up... :O cause I know I'm not running pig rich.....
    Mines also 10:1 @ 8psi spraying just a bit at 5psi and above(60ml nozzle). Using a autometer egt and located on front manifold where all three logs join. At idle im at 800-900F. Cruising streets~1200-1400F. 65mph highway 3rd gear 1300-1400F. WOT from 2000rpms to redline in 3rd hits 1450F. Before the water spray would hit 1600F. I only use water though, no meth. So far i only had my egt gauge for 2 weeks now so im pretty new to it. As long i stay between 1000F-1550F during WOT i could care less. lol
    @ just 8 psi, I'm not surprised your peak EGT's are only 790 deg C. I'm not sure why you think they need to stay below 850 deg C, though. Regardless, I hope you're not using it as a primary tuning tool.
    of course not. i just prefer no more than 16oo.
  4. #24
    Yes those are Celsius, using an Apexi gauge. Should probably note that I'm running 93 pump only.
  5. #25
    according to this thread, some of you are running exhaust temperatures which should be melting the catback clean off you car.
  6. #26
    not sure who u are referring to but im going off by the same values as jeff lucius page
    Stealth 316 - EGT pyrometers
  7. #27
    you're kidding, right?
  9. #29
    The other technique is a little more subtle but usable if attention is paid to EGT (Exhaust Gas Temperature). Detonation will actually cause EGTs to drop. This behavior has fooled a lot of people because they will watch the EGT and think that it is in a low enough range to be safe, the only reason it is low is because the engine is detonating.
    Ha! EGT's are even less useful than I'd ever imagined.
  10. #30
    I use Titan/DR exhaust parts...
    Melting temp of 304SS: 1450 deg C. So @ 1100 deg C EGT, I'm at .76Tm in the headers.
    The inside of my O2 housings do look fairly rough, though... 304SS is 18-20% Chromium, so it should be pretty resistant to oxidation/scaling up to 870 deg C.
    This is the best argument I've ever heard for keeping EGT's around 900 deg C (longevity of headers).
