Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Normal EGT reading
    Madison Heights, Mi
    Normal EGT reading
    If you've got a EGT what do you see cruising down the free way?
    I see 650-700 at about 3k RPM doing 80 in 5th.
    I'm just curious to see if thats in the normal ranges.
    Never finishes any verified
    Wake Forest, NC
    Everyone will also need to state where their EGT probe is located. Some are before and some are after. Front or rear bank? Also F or C?
    Mine is after the turbo on the rear bank. Choose after the turbo as it anything on it breaks it doesn't Fubar my turbo.
    I think I'm about 750-800F 80mph 5th gear. But i'm also 10:1 TT so mine is going to be a little higher
    Full out pull at 14psi, 93oct and 30/70 meth/water up to 6k I never get over 950F
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    I've never heard of an EGT probe breaking off and flying through a turbine. The temperature after the turbo is a function of how much work the turbo is taking out of the exhaust stream, so it's not going to be as readily useful for tuning purposes... Not to say EGT probes are all that useful for tuning anyway... But if you're going to put the EGT probe post-turbine, you might as well not have it.
    the BOSS of jellow supporter
    May 2005
    Dairyland
    front, before turbo. cruzing = 1000 F, WOT = 1500F, idle = 600F
    I'm 98% sure of accuracy info above. sometimes I just forget...
    Man vs 3/S verified
    Kingston, WA
    700 cruising, same as yours, Alan. If I do a 3rd/4th/5th pull to 130 or so its up to about 950. Mine is placed in the front manifold where the 3 meet.
    Cruising up a hill at 2500 with 0-3 PSI it will be around 825. cruising downhill it goes way down, 300 if the hill is long enough.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    Wake Forest, NC
    If the probe were to melt and break off it would fubar the turbo. Granted the probes are now in a SS sleeve, that chance is still there. The temp reading difference of running the Probe after the turbo is 200-300 degrees what it would be at the head.
    The ones I originally posted are my straight numbers. I am used to compensating for the location of the probe in my head. I'm updating my numbers in the first thread with the compensated numbers.
    On a side note I am awaiting a second probe that will be installed before the turbo so I have absolute comparison numbers. Most likely won't be till next year as the Stealth is down for the winter now.
    Madison Heights, Mi
    If you have enough heat to melt the probe you have other issues
    Quote Originally Posted by Alan92RTTT View Post
    i agree, On a side note the egt should be within 3inches of the exhaust valve to be the most accurate. I have not installed mine yet ill have one on each bank.
    Front header. 6-700C at cruise, just over 1000C when pushing the car
    VR-3747 :D Not Verified
    Dayton Ohio
    C or F?!
