Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: Normal EGT reading
  1. #41
    Just a little update:
    With the new engine management my highway cruise EGT's are now 7-800C.
  2. #42
    Here's what the inside of my 1200C sensor looks like:
  3. #43
    Couple of thoughts on the subject since I successfully ‘tuned’ by EGT, narrowband and datalogging back in the day:
    900-1000 Celsius at WOT is perfectly acceptable and frankly normal assuming your probe is in the manifold pre-turbo where it should be (this is TD04 only). If WOT EGT’s are under 800C and the probe is in the manifold then you are wayyy too rich. When I went 11.4 @ 125 peak EGT’s were closer to 1100 at the top of 3rd. I saw 1300-1400 on a few occasions which resulting in burning up the probe but no ancillary damage. These spikes would be a result of high RPM, high load, high boost where detonation was encountered and the ECU reacted by pulling timing (retarded timing = higher EGT’s). You will only see these spikes with an unshielded probe, though; if you’re running a slow-reacting shielded probe you might was ignore the gauge altogether because honestly EGT is pretty worthless. I used to run the TRE probes back in the day and they would react almost as fast as the boost gauge, but they didn’t last more than 5k miles or a couple of 1300-1400 spikes. That said, in my experience EGT’s surpassing 1000C typically mean you’re running too much boost for the octane and timing is being retarded, or on the opposite end of the spectrum you’re not running enough timing assuming no det/knock. There was a big ‘more boost, less timing’ kick about 8-10 years ago and through my own experimentation I could run 21-22psi on pure pump with the timing dropped to the floor but the EGT’s were through the roof, the car was lazy and ultimately slower than it was at 16-17psi with a ton of timing. TD04 cars simply NEED timing to make good power; consequently lots of timing results in cooler EGT’s.
    Bottom line though RE: EGT’s is they are worthless now that widebands are cheap and readily available everywhere.
    Formerly:
