New firmware2.07 is up on http://www.lcdboostcontroller.com .
Here's a list of changes that aren't in the manual yet.
Inside the setup config menus:
WBO2 input=none
(WBO2 is replaced with NBO2 in main screen).
Push to toggle
startup color
7 total colors to choose from (Red, Green, Blue, Cyan, Yellow, Purple, White).
PSIsensor=Intrnl (Internal 2.5bar 0-36.3psi sensor)
=Gr4Bar (Greddy 4 bar pressure sensor)
=GM3Bar (GM 3 bar pressure sensor)
Datalog=Off (no datalog operations)
=passthru (allows external dataloggers such as HHH, Evoscan)
=TxtMode1 (57.6k serial, timestamp, PSI, WBO2, Knock, RPM)
=TxtMode2 (57.6k serial, timestamp, PSI, WBO2, Knock, RPM, EngineLoad)
=TxtMode3 (57.6k serial, timestamp, PSI, WBO2, Knock, RPM, EngineLoad, Timing)
A free program called CoolTerm can be used to monitor the serial port at 57.6k baud (8N1).
PassThru=1953 baud (OBD1 speed)
=57600 baud (HHH, Evoscan)
=15625 baud (Evoscan)
AudioBuzzer=On (Alert audio on)
=Off (Alert audio off)
98/99 3000GT=Yes (support for different rear fuel trim codes)
=No
Test solenoid = Activates boost solenoid at 50% duty cycle for 2 seconds.
Test Buzzer = Activates audio buzzer for 1 second.
Calibration=xxx
Factory calibration can be tweaked for more reliable 57.6K serial connection.
When editing the calibration number, the datalogging port will broadcast a string of
"0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklm nopqrstuvwxyz" continously. If the string appears incorrectly, your calibration number is no good. Generally there are 16 valid calibration numbers, the ideal calibration number is not the highest value but the third highest. A free program called CoolTerm can be used to monitor the serial port at 57600 baud (8N1).
On the "WBO2 PSI KNOCK" main screen, if you quickly press the button it will toggle the display from bright to dim. Pressing again will make it bright again. Holding the button down longer (1 second) will toggle the display colors.
On the "Throttle Airflow" screen, pushing the button quickly will allow you to cycle through the colors faster.
. I'll remake the video again.
