Good job black. Keep up the good work!
Updates on the datalogging capabiities:
I've tested it on two pieces of software Evoscan and Hand Held Halo (HHH) and both are working great. In fact I have Evoscan and HHH datalogging at 57600 baud (much higher than stock 1953 baud and 15625 baud) so this means passing extra information such as WBO2 and Boost data won't slow down communications. The other good news is WBO2 and Boost can be dataloged very easily which are very important. I looked for some unused PID request codes, and created new ones that now represents both WBO2 and Boost. Both of these software packages are flexibly enough to accept new PID request codes making it easy to log these new items.
At the moment only the OBD1 version of HHH will work. I haven't had tried any other HHH version yet. Why OBD1? Because the datalogging port converts all ECU connections (OBD1, MUT, or MUToverOBD2) into OBD1 style communication at 57600 baud, or 1953 baud (software configurable). OBD1 and MUT are 99% the same so no need to panic unnecessarily. MUT has an annoying handshake that I want to avoid that slows things down at the start of datalogging.
For Evoscan you only need to change the connection style (one click) and adjust the baud rate to 57600 baud and you're done. Data still comes in the same manner as before.
Also, I need to know how many people need a MUT serial cable (for 94-99 cars)? I have six in stock, and ordered ten more.
I'm a '99 car here.
So we'll have to load the datalogging software of our choice on it?
Do you think it will work fine with the flashable 99 ECUs? And what are you thinking price-wise about those of us who will upgrade?
1992 3000GT VR-4
Any more thoughts about making it AEM compatible?
R.I.P Spyder you are missed.
93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
Is it possible to upgrade the first batch of controllers with the new features or even buy just the newer version main black box without all the extra parts/wiring?
Hmm I lost my previous message. Okay here I go again.
Yes previous generation hardware will work with the new unit, so you only need a new black box. I will sell them at cost and charge no labor to reward and encourage the early adopters. I have no shipping boxes at the moment to ship them out. Send me a private message if you want to upgrade.
AEM version will follow after the Nissan version.
Datalogging software is not loaded into it. Think of my device as a datalogging cable, it allows you to use HHH or Evoscan. I discovered a software bug during dataloging that I'm investigating now. I hate those kind of surprises. lol.
