I did load the 99 vr4 rom. I'm having an issue with evoscan freezing when I try and log in 3000gt/dsm mode. OBD2 will connect, but obviously I want to use the 3000gt mode so I get all the correct sensors and can log knock. I haven't done much other than start the car. It starts right up, idles ok, I backed it out into driveway and pulled back into the garage, but I don't feel comfortable doing anything more until I've got the logger working properly and have verified everything's working as I expect it to.. It's wanting to idle real lean, but I suspect that's just because I don't have my values for the PTE 550 injectors right. I found latency settings for just about every other injector, but not the 550s.
Pin 1 on the OBD2 plug needs to go to pin 84 diagnostic ground pin. This puts the ECU into MUT mode when ground is present.
p.s. I'm also running a 99 3000GT VR4 ECU into my 93 car, loving it so far.
I can use both modes. One mode is MUT mode, the other mode is OBD2 which encapsulates MUT requests at a slow rate.
My cable is a boomslang harness which I verified and corrected. Someone was selling the 99 3000GT VR4 ECU, Boomslang conversion harness and OpenPort 2.0 cable so I purchased it all.
Great thread thus far. Been thinking about doing my own harness.
subscribed.
subscribed...
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
I have the harnesses for 1g, hybrid, and 2g available through morgon's motorsports (xwire), all come with a reflash plug and the 1g comes with an obdII port.
You can source all of the parts and DIY - but if you look at the prices of the hard parts and factor in S&H of the hard parts, then factor in your time, your loss of hair, etc, etc, your not saving your self any money and you are def costing yourself TIME. Now I have been fabbing these up for some time now. I make 10 to 20 at a time. I have had to teach my poor gf how to solder and junk because it is just such a PITA.
So, for the unconvinced:
Lets look JUST at the 99 ecu plugs:
28 Pin Plug 1 @ $2.50 ea add 17.00% for average S&H from DigiKey $2.93
28 Pin Plug Pin Retainer 1 @ $0.75 ea add 17.00% for average S&H from DigiKey $0.88
30 Pin Plug 1 @ $5.16 ea add 17.00% for average S&H from DigiKey $6.04
30 Pin Plug Pin Retainer 1 @ $0.75 ea add 17.00% for average S&H from DigiKey $0.88
35 Pin Plug 1 @ $2.73 ea add 17.00% for average S&H from DigiKey $3.19
35 Pin Plug Pin Retainer 1 @ $1.18 ea add 17.00% for average S&H from DigiKey $1.38
Sig (Small) Pin 75 @ $0.38 ea add 17.00% for average S&H from DigiKey $33.35
Pwr (Large) Pin 18 @ $1.04 ea add 17.00% for average S&H from DigiKey $21.90
TOTAL $70.55 - Thats just for the 99 ECU side
Figure about $10 to $13 bucks for the 1G or 2G ecu connector.
Oh - and if you have a 1G, you need an OBDII Port. And dont forget the mitsu reflash plug.
So figure at LEAST $100 in parts. No Wait, add solder, heatshrink, and wire. You shouldn't just slap any old wire into those 99 ecu connectors. The pin crimp specification is 1.4mm wide on the signal pin. Soooo if you crimp 1.7mm wide because you are not using ultra thin wall (TXL) wire, you will have to work real real hard in stuffing all those pins in the connector. But I suppose if you want what they pass of as primary wire at your local auto parts store, then by all means have at it.
Now you got your conversion table - what pin goes to what pin. Don't make a mistake or you might be buying a new ecu. You get everything fabbed up and how much time did you spend? I bet at least an hour or two. Do you figure your lost time with your family and friends is only worth $2.50 hr? Any way you slice it, it is so much nicer to just order the part, slap it in, and walk away . . . that being said . . .
Von can yell at me later - I have the 1G / hybrid / 2G connectors available through Morgan's Motorsports (xwire). Everything is built with extra thin wall TXL cross-linked polyethylene wire rated at 60v and between -59°F to 275°F. Resistant to moisture, grease, oil, gasoline, and most solvents. It meets or exceeds SAE J1128. Check with xwire for pricing.
What is your price then?
