Results 1 to 4 of 4
Thread: Starting: Low to High RPM Flux
    aka PierCove Not Verified
    Indiana
    When I start my car after it hasn't been driven a while (overnight, maybe 5-6 hours) or more, it needs to "warm up". After starting it, it will fluxuate between about 700 RPMs to 1900 RPMS for about 1 - 2 minutes and then "level off". This has gone on since last August, and I'm not quite sure what to make of it. Once "warmed up" the car works just fine without hesitation, etc.
    I've got many mods on the car, the most recent in July of last year, the FMIC w/ all hard pipes and TopGear Cam Gears.
    Other Mods:
    - 720CC Injectors
    - MAFT Trans
    - GM MAF
    - Upgraded Fuel Rails
    - Hotwired Fuel Pump w/ Supra Pump
    - 16G MHI Turbos
    - APEXI AFC2
    - ARC 2
    - Manual Boost Controller
    - FMIC & Hard Pipes (listed above)
    So, some things I found "may" hint to a TPS sensor or something like that, or is this something different?
    Fowlerville, MI
    What's your AFRs during this time? Usually I'd point to ISC/IAC but I could believe MAFT would cause it. I have the Cam gears, too and my car idles fine.
    Indiana
    I'm not thinking the cam gears or anything else for that matter. I think that maybe the Idler or something else is "off". Cam Gears wouldn't cause this effect and then be fine after a minute.
    Maybe the introduction of the FMIC is causing better airflow and I have to adjust my SAFC, but I did take it to -40% which it barely could keep the car running (at idle) and then -20% which was running rich. So, my conclusion is that there is some OEM thing i need to adjust.
    Quote Originally Posted by TurboX2 View Post
    Whenever my idle moves around I have a lean or rich spot. Let the car settle into a smooth idle, the watch the instant o2 trims as you go through that rev range.
    How do you have a maft AND an arc 2
    Sent from my DROIDX using Tapatalk
