When I start my car after it hasn't been driven a while (overnight, maybe 5-6 hours) or more, it needs to "warm up". After starting it, it will fluxuate between about 700 RPMs to 1900 RPMS for about 1 - 2 minutes and then "level off". This has gone on since last August, and I'm not quite sure what to make of it. Once "warmed up" the car works just fine without hesitation, etc.
I've got many mods on the car, the most recent in July of last year, the FMIC w/ all hard pipes and TopGear Cam Gears.
Other Mods:
- 720CC Injectors
- MAFT Trans
- GM MAF
- Upgraded Fuel Rails
- Hotwired Fuel Pump w/ Supra Pump
- 16G MHI Turbos
- APEXI AFC2
- ARC 2
- Manual Boost Controller
- FMIC & Hard Pipes (listed above)
So, some things I found "may" hint to a TPS sensor or something like that, or is this something different?
