Aloha,
While swapping in a set of DR-650's I decided to go with the 3SX SS Oil & Coolant line kits. I believe I've got the coolant lines 100% correct, however, I want to make sure that I've got the oil setup correctly before wrenching everything down.
Namely, there are 4 AN to pan/turbo fittings, three of which are straight through, and one is a 45*. From how I have it setup, the 45* goes on the front turbo, facing outward.
The return lines themselves have one straight end each, and one degreed fitting. I currently have the degreed ends attaching to the turbos, and the straight through attaching to the pan.
Finally, I don't really see a way to run the rear manifold heat shield, as the oil return would be dead rubbing the bajesus out of it.
Can anyone who has been down this road confirm?
Front Turbo:
Rear Turbo:
