Just to keep this up to date...I'm probably going to try the XYZ Gravel Coilovers...not expecting much so we'll see.
they want 2K AUD for them...working on improving that.
They are 6kg front and 5kg rear
85cm outer diameter (so I can compare them to my Teins and see if I loose any tyre space)
front travel is 170mm rear 125mm
looking at a slightly stronger set of sways...will see how I go down the track (prob a month before I get the shocks)
