The front tie rods have square sections that you can put a wrench on, but the rear doesn't have that. How do you adjust the rod? Just wrap something around the thread and gently use pliers?
Can't find the answer in the manual or online. No search here brings anything up. And since 3si.org has problems, I can't search there.
Background: I've adjust the camber and toe in the rear via the cam bolts and need to match up the tie rods.
Thanks,
Climber
