For those of you that have upgraded your tank-filter line, where did you run it? I'm guessing that it will fit where the stock line is but I'm not 100% sure.
Pictures would be greatly appreciated.
I ran my -8AN line where the stock line is. It's a little bulged, but it fits.
I also ran mine under the plastic piece after I removed the hardline. It is also zip tied to the return/vent lines for added security.
I ran mine down the driver's side. However I also had the front subframe out, and did a AWS delete.
Thanks guys, after twisting the short feed hose from the tank in half & bending the hell out of the hard line I decided it was time to upgrade. I'll let 'yall know how it goes.
I'm still waiting on Oohnoo to finish my fuel setup...CAMOOOON MANZ!![]()
1996 GTO, Owner since 2003.
he has a full kit that he designed a while back..it's the best I've ever seen 8an or 10an from tank to engine bay, big filter, then guage, then through Y to dual rails, then Y back through FPR with guage and back through return..
unfortunatly Oohnoo has to redo mine as it's got the 75 Mivec heads :| (and he's doing the water neck)
