Results 1 to 10 of 14
Thread: Upgraded Fuel Line
    Upgraded Fuel Line
    For those of you that have upgraded your tank-filter line, where did you run it? I'm guessing that it will fit where the stock line is but I'm not 100% sure.
    Pictures would be greatly appreciated.
    One fix at a time verified Feedback Score 4 (100%) TurboSinceBirth's Avatar
    Kansas
    I ran my -8AN line where the stock line is. It's a little bulged, but it fits.
    Never finishes any verified
    Wake Forest, NC
    I also ran mine under the plastic piece after I removed the hardline. It is also zip tied to the return/vent lines for added security.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    St Joe
    I ran mine down the driver's side. However I also had the front subframe out, and did a AWS delete.
    Thanks guys, after twisting the short feed hose from the tank in half & bending the hell out of the hard line I decided it was time to upgrade. I'll let 'yall know how it goes.
    Forum User Feedback Score 0 Beef6's Avatar
    There's no need to upgrade the line if you mount your second pump up front in a small tank.
    The original pump supplies the injectors and overflows into the second tank from the reg(s), then overflows back to the main tank so it's always full.
    Then all you need to do is tee the 2 pumps together and have the second pump switch in when you want it to.
    Why do un nessecary upgrades?
    Steve
    I fail to see how adding a second small tank with a pump in it is less of a "unnecessary upgrade" than adding a new fuel line...
    Because it's a whole lot easier and cheaper and more effective. It's also less likely to have reliability problems due to retaining the stock lines.
    Steve
    This has to be a joke.
    I'm still waiting on Oohnoo to finish my fuel setup...CAMOOOON MANZ!
    1996 GTO, Owner since 2003.
    Details?
    he has a full kit that he designed a while back..it's the best I've ever seen 8an or 10an from tank to engine bay, big filter, then guage, then through Y to dual rails, then Y back through FPR with guage and back through return..
    unfortunatly Oohnoo has to redo mine as it's got the 75 Mivec heads :| (and he's doing the water neck)
