That is the coolest hood ever
That hood looks sweet, but not very functional :P.
fyi:
Pit Fighter Hood | Z16A/Z15A [H28A(CF)] - $599.00 : Chaser Aerodynamics, LLC.
this is how the pitroad m should look. the FG one is only $299, and at that price, i might actually consider it. not the best "OEM-looking" hood, but it does vent the best.
hood like this
so I could mount the radiator like this
thanks
again, you're wrong. look at the front edge of where the vents begin. yep, that's a 90-degree angle. the sides of the vents may curve slightly, but the leading edge of each vent? 90-degrees!
at the VERY least, the gt-300 needs to have the leading vent's front edge rounded off. it would look 200% better if that one vent was rounded.
something like this maybe:
IPD you blind? the inner lines of the vents have a slight curve.
if they are, you certainly can't see it in any of the pics. every pic i've seen of the hood, from every available angle...makes it look like the vents were cut out with a box-knife; there's no curves anywhere. i'll be happy to take a "closer look" at someone's hood at NG--although i can't imagine it'll change my mind.
if i had any fabrication skills whatsoever, i might actually attempt to use a pair of damage 2g 3kgt skirts and see if i could fabricate a custom vented hood; using the fake brake ducts as vents, rather than scoops. it would certainly fit my car's lines better.
hey gonzo can you make me a evil eye hood for my stealth. I now someone with an extra hood
