Page 15 of 43 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 422
Thread: SMIC vs FMIC
  1. #141
    Advanced Tech? verified
    i agree. and yet...every time someone has gone from smics to fmic, they've posted better dyno numbers. just saying.
    thats mostly due to the reduced friction loss with the larger cross section area. here's the original post from brian g (I think thats his name).
    DSM Sidemount Intercooler Testing - 3000GT/Stealth International Message Center
    DSM intercoolers drop 5.5 psi at the top end when you're running ~17 psi before the core. Keep in mind that DSM smic's already have about twice the cross flow area of the stock SMIC's.
    With a greddy FMIC, the drop is ~1.5psi at the top end. Also, because the drop is less, the boost controller doesn't have to "hunt" to find the correct duty cycle. boost pressure is much more steady.
  2. #142
    Of course they see better dyno numbers - a dyno pull is a short burst of power, so the FMIC is fully in "heat sink" mode the entire time. Most FMICs will have way more thermal mass than SMICs (certainly better than the OEM SMICs) so they perform better.
    Pressure drop is largely a function of core and end tank design; neither location has a real theoretical advantage, although it does take a little more thought to build a free-flowing SMIC setup than a FMIC.
    FMICs work, but typically, they are hacks - they DO make better power, but don't get anywhere near their full capability. Properly engineered SMICs can produce the same power levels, plus they work better as heat exchangers, plus they don't impact engine cooling the way a FMIC can.
    I'll say it again - short bursts of power, go FMIC. Extended use (street or track use) go SMIC.
    DG
  3. #143
    fair enough. my car will still be a daily, and will only occasionally see any track/drag use. FMIC for me.
  4. #144
    I think if you had an identical amount of pipework that SMIC's would have less lag too.
    1996 GTO, Owner since 2003.
  5. #145
    this comparison is kinda stupid. See hes running different sized pipes and unknown piping configuration and different sized cores so many variations that you canīt really do equal comparison.
    however this does prove that he had a bad combination of parts when he tested the dsm smics
  6. #146
    If we are looking at the flow only
    For ten feet of 1.5"-diameter smooth pipe, calculations using the web pages noted above suggest that pressure loss should be about 1.2 psi at 15 psi boost (near sea level), 360 cfm (before compression) flow (in each half of our IC system), with an air temperature of 200šF.
    A 2"-diameter pipe could flow about 720 cfm (before compression) with a pressure drop of about 1.1 psi, about the same as a 1.5"-diameter pipe flowing only 360 cfm (before compression). So at the same pressure loss the 2-inch pipe will flow about twice as much air as the 1.5-inch pipe .
    Then you add bends into the configuration and you have unknown outcome, every bend restricts flow and increases pressure drop.
    http://www.stealth316.com/2-ic.htm
  7. #147
    Quote Originally Posted by DG View Post
    Except, of course, that most of those cars are rear engine.
    I've seen that Compuware Corvette in person - the P&M shop was just up the road from mine, and I used to buy their old parts from them. The engine in that car is in the front, but it is set back so far that half the motor is under the windshield glass. The radiator is completely ducted to that vent in the hood - as in, there is sheet aluminum ducting that seals the back end of the radiator to the duct in the hood so that there is no way the exhaust air can go anywhere except out the duct.
    You cant set back the engine to gain clearance (and a better CG) because the engine/transmission is tied to the front axle centreline.
    DG
    yes but all the jtcc, jgtc/super gt and german touring cars have hood vents alike and most of those cars have front engine layouts .
    yes
    yes
  8. #148
    On that 3000GT, even with that huge vent, the outflow air from the radiator dumps onto the engine block, and that disrupts the flow path. Most of the exhaust air will still go under the car, not out the vent, unless there is ductwork on the backside of the rad to seal it to the vent - and good luck packaging that.
    DG
    all in all we are not building le mans winner here, but I "think" proper ducting could be done to ensure that if not all but atleast most of the exhaust air goes out the duct
    this is a radical example
  9. #149
    another radical example
    (v mount in this case
    intercooler
    radiator
  10. #150
    that's EXACTLY the point. he had the two most common configurations available to a 3/s owner. a dsm fmic with factory piping, or the greddy fmic. You don't just buy the cores, you buy the cores and pipes.
    From what I gather, your "proper" comparison would be to use a single smic in the front... or use two giant fmic cores on the side. Is that correct?
