Permatex Ultra Black, HI-TEMP RTV SILICONE GASKET MAKER PX#82180
Never heard of "The Right Stuff". Is it that much better? I have not put the pan back on yet and may want to get some. Engine is on the stand.
the right stuff is in a bottle with an aplicator and looks like something you would get cheeze out of for some crackers. it comes out like toothpatse and i do a 1/4 inch bead with 1/8th around each hole. to me its alot easier than the jelly like silicone that smells like ass and gets everywhere.
I've always been a believer that silicone sealers should be a CONTROLLED SUBSTANCE just like freon 12. Sooo many people abuse it badlly and cause more problems that they started with. This thread confirms my experience with all the different "ideas" and abuses of a product.
Any of you actually wonder WHY they make more than one color/formula?? I guess not since most of you just use RED anyway. For me those red worms sticking out the sides of an engine just let me know someone else has been inside and screwed it up.
From a manufacturers rep at a trade show: ALL formulas are oil resistant. It used to be that only the orange was oil resistant.
Application: Just like on ANYTHING else the surface has to be clean and dry. A SMALL bead (like on an oil pan) or a THIN film (on a gasket or manifold) is all you need. If you can see it oozing out the sides you used too much. Keep in mind that all that excess you see on the outside is also oozing on the INSIDE and can end up almost anywhere inside your engine.
I know most of you on here can read so DO IT and buy the right product for your job. to the OP of this thread: I'm suree you did SOMETHING wrong to cause the failure. Learn from your mistake and do it right from now on.
Happy wrenching everyone!
-SP
