Results 1 to 10 of 24
Thread: RTV huh..
    Forum User verified Feedback Score 1 (100%) Amphiron's Avatar
    RTV huh..
    Used the stuff from auto zone. Everywhere I used it during my rebuild is leaking. Sweet. Don't use Permatex, period.
    2004/5?
    SW Connecticut
    I've used gray permatex rtv several times on oil pans with no leaking issues. I also use a different kind of permatex thread sealer on fuel line products, works great for me. Not trying to be a dick but maybe there's a bit of operator error involved? I know it can be tricky to put the oil pan on without catching the freshly RTV'd edge on the oil pickup, thus smearing everywhere and destroying chances of a good seal.
    Everything was sealed fine until the engine started to overheat now it all leaks. It was red RTV.
    Rochester, NY
    Never had a problem with Permatex.
    I've used the cheap stuff and 'The Right Stuff' without issues. Maybe you didn't clean the surfaces properly? Or something warped from overheating? Or the temperature it reached was higher than the RTV you selected was designed for?
    It's designed for 650f. I spent a lot of hours scraping off old gasket until all I seen was nice clean shiny metal on EVERY mating surface. I guess it just got too hot.
    Member Not Verified Feedback Score 3 (100%) Unknownvr4's Avatar
    i used the black permatex on everything and nothing leaks on mine..
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
    Why? Because Race Car. verified Feedback Score 0 akotten's Avatar
    Wichita, KS
    Where are you leaks coming from?
    91 R/T TT
    Not A DSM verified Feedback Score 3 (100%) Polygon's Avatar
    June 2006
    Utah
    Quote Originally Posted by Unknownvr4 View Post
    Same here. I've always used black Permatex with no leaks.
    Always used black permatex, and no issues.
    Diamonds and Rust Feedback Score 1 (100%) gltasn's Avatar
    ak
    black or grey is for oil, blue is for h2o, red/copper made to resist heat. i like permatex black for the pan not the silicone but the bottle called the right stuff. get the 15min set time as the 1 min is kinda short unless you are a fucking pan master like me!
