Results 11 to 20 of 24
Thread: RTV huh..
    Honda Eater
    April 2007
    Ontario, Canada
    I used to use Permetex.. you have to scrape off the old shit with a razor blade real good, and then rub the surface down with varsol on a rag to ensure the surface is clean. Then you squirt that stuff on, finger tight the bolts, let it sit for 30min to an hour, then tighten them.
    I used the red Permetex on my oil pan and it worked great. But now i use Mopar silcone RTV lol.
    Player Hater of the Year
    San Antonio, TX
    Quote Originally Posted by Amphiron View Post
    It's designed for 650f. I spent a lot of hours scraping off old gasket until all I seen was nice clean shiny metal on EVERY mating surface. I guess it just got too hot.
    After scraping did you de-grease it? I usually scrape crean, run sandpaper of the surface once and then degrease it to get ALL the oil off.
    July 2005
    Arkansas
    Yup no issues with black permatex here either. Thinking the surface wasn't prepped right...
    Ft. Lauderdale, FL
    Red RTV may not be oil/fluid resistant. The only time I got red RTV was from a hardware store and I think it's meant for oven doors and stuff like that. Orange for exhaust parts, blue/grey for water, "right stuff" or black (not quite as good) for everything else. I have 100 times fewer problems with RTV than I do with traditional gaskets.
    Never finishes any verified
    Wake Forest, NC
    I used the red on my oil pan and it sealed up just fine. You have to let it set for about 5-10 min before you torque everything down. no leaks on the pan.
    I did use the red on the turbo oil return lines and they just started slowly leaking. So I either didn't use enough or they didn't set long enough.
    When it comes to RTV it is all in the prep and application methods. I have seen it work flawlessly when done right and I have seen it fail miserably when the user didn't do it correctly!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    I torqued everything down right away. Guess thats why its leaking.
    Wrench Monkey Not Verified
    Rochester, NY
    I've always torqued everything down right away, and ran the engine shortly after without issues.
  8. #18
    Used black/blue/copper Permatex with never one issue. Fantastic product of excellent quality and I'll keep buying it. And I've done 6-8 rocker covers, exhaust manifolds, 2-3 sump's and various other parts.
    I don't think the product is to blame here.
  9. #19
    I used red/orange on my buddies oil pan and it worked perfectly.
  10. #20
    Honda Eater
    April 2007
    Ontario, Canada
    red Permetex is good for oil pans.. you just gotta remove all the oil/grease/debris, squirt that shit on, put the oil pan, finger tight the bolts, wait 30min, then torque them down.
    You shouldn't have any leaks if you follow those steps.
