Page 29 of 43 FirstFirst ... 19272829303139 ... LastLast
Results 281 to 290 of 423
Thread: Engine Bay Pics
  1. #281
    Never finishes any verified
    Wake Forest, NC
    I've actually though about doing some anodizing at home. I've see a bunch of people do it with pretty common stuff. Doesn't look to complicated.
    I really want to see how the purple comes out. I've heard it is one of the hardest colors to get to look right!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  2. #282
  3. #283
    chrome i wanna see chrome
  4. #284
  5. The Following User Says Thank You to The Linchpin For This Useful Post:
  6. #285
    i did it for a while. the quality of alu varies and can mess with the results (cause blotchiness‘). high quality alu worked great, cheep stuff came out like garbage lol. im sure a pro setup would work better than mine on the poor quality alu, but i still had around $1000 into my setup so it wasn’t too 'back yard'.
    for an example, dirt bike triple clamps wouldn’t come out with an even shade of a color, unless a dark dye was used. Black would work on almost anything, red could sometimes look pink, orange could look yellow, ect. An OEM clutch lever or brake lever would always came out beautiful. i tried a cheepo aftermarket lever and it just dissolved in the sulfuric acid. iirc the zinc in the alu alloy can be dissolved into solution by the sulfuric acid which explains why cheep alu never came out good and would sometimes get some minor pitting. Its been ~3-4 years since I last did this so maybe there have been some improvements in the process since then.
    Check out casswellplating.com and there is a really great ‘how to’ on diy anodizing for color and strength on ‘uponone.com’ (motorcycle website)
    http://www.uponone.com/viewhowtos1.php
    EDIT:
    "Type III (hard coat) anodizing is done at a much lower temperature and higher current level. It gives an anodized layer up to .002 but is normally at .0005" (Mil spec) in most anodizing shops. Type III anodized surfaces can typically only be dyed black or dark green."
    after re-reading my color issue might have been due to the alu quality and the low temps/high current/long bath time that i was utilizing.
    Mine:
    and yes my ic was crooked in the photo, its better now.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
  7. #286
    Seattle, WA
    NW3S, Slayer engine photo.
    Here's a quick shot for you of the NW3S Drag Car engine bay.
    http://nw3s.net/racing/photos/engine1_11_edited-1.jpg
  8. #287
    Canaan NH
    I want to see the rest of that car. Looks to be a awesome flame job from what I can see.
  9. #288
    Man vs 3/S verified
    Kingston, WA
    Flames, and dragons, and, its pretty much the most complex paint job you have ever seen on a 3S.
    All its missing is a naked blonde chick.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  10. #289
    Seattle, WA
    That's easy.
    NW3S Racing - 3000GT Drag Racecar has some specs and photos.
    No naked blonde chicks though.
  11. #290
    Canaan NH
    SO SICK. Very nicely done. Thanks for sharing.
