Don't forget about clutch and tranny brace.
I'm running 15G's fine on a otherwise stock caryou need other stuff when you up the boost, not the turbo size
(imho)
1996 GTO, Owner since 2003.
I think the 750s are actually capable of 600awhp, you'd prob be fine with 15g turbos. Everyone talks about Evo turbos this and that but honestly guys, a set of 15gs should see you 320awkw+ with supporting mods ie fuel, fuel control and cooler. Heck i've read some cars running about 370awkw with a bit of headwork etc. Dont think too many people would want nor be able to handle much more than that safely. 600 awhp which the 750s would give you works out to be something like 420 awkw, your talking mid 10s power there.
Also a transmission brace isnt rice, 2nd gens actually need it due to the aluminium construction (correct me if am wrong) of the 6spd bell housing. Nothing to do with engine mounts what so ever. Also think that td04 is a much better option, instead of fooling around with manifolds n what not. You can make same power at the same end cost by going with a set of dr750s instead of evos. imho
Maddy
You do realize the tranny brace is welded inside the bell housing, and has nothing to do with your heavy duty pressure plate or motor/tranny mounts right?
If anyone is interested in learning about it search it, or pm Ray Papanya. IIRC it's recommended if launching with 450 awhp and up. (or 500)
erm
it's not exactly a trans brace...or that's not your best way of describing it...it's kinda a beef up plate that's welded into the bell housing, the trans brace sounds like the transfer case brace...which I believe does nothing (since by the time it's under load the case itself would need to have broken)
There are a couple versions, but yeah that is what I was talking about. My bad, it is the tranny bell housing brace. Even the transfer case cage has nothing to do with mounts or pressure plates as mentioned. In fact just the opposite. The more solid your mounts, the more stress it puts on the drive train during a launch. I.E. nothing flexing to dampen the torque.
If interested here is a good read. Info about power and which housings are found in there, but may have to read some to get to it...
Pampena Motorsports Bellhousing braces CLEEEAAN INSTALL! - Page 3 - 3000GT/Stealth International Message Center
lol, I was looking through the smilies listsaw it and had to use it
Picard was the best captain.
