Results 21 to 30 of 31
Thread: Upgrades
    Don't forget about clutch and tranny brace.
    I'm running 15G's fine on a otherwise stock car you need other stuff when you up the boost, not the turbo size (imho)
    1996 GTO, Owner since 2003.
    not far from breaking down
    If you change the turbos you will need to also change the fuel pump, fuel pressure regulator and injectors then you will need some sort of device so control air and fuel. Welcome by the way. Also you should look at the dynamic racing DR750s. They are awesome turbos capable of 600hp.
    I think the 750s are actually capable of 600awhp, you'd prob be fine with 15g turbos. Everyone talks about Evo turbos this and that but honestly guys, a set of 15gs should see you 320awkw+ with supporting mods ie fuel, fuel control and cooler. Heck i've read some cars running about 370awkw with a bit of headwork etc. Dont think too many people would want nor be able to handle much more than that safely. 600 awhp which the 750s would give you works out to be something like 420 awkw, your talking mid 10s power there.
    Also a transmission brace isnt rice, 2nd gens actually need it due to the aluminium construction (correct me if am wrong) of the 6spd bell housing. Nothing to do with engine mounts what so ever. Also think that td04 is a much better option, instead of fooling around with manifolds n what not. You can make same power at the same end cost by going with a set of dr750s instead of evos. imho
    Maddy
  4. #24
    The 13Gs on mine (red 91) run fine with stock pump & injectors and AFC. Even done a 12.8 / 106 like that a few years back. Your power output is pretty much limited by knock / stock intercolers / pump fuel (98 RON?). There's pretty much no difference in airflow at X pounds boost regardless of the turbo.
    Tranny brace? that's another ricer product as a band aid for broken engine mounts. Mine's got a heavy duty pressure plate.
    Best value turbos for the $$$ spent are genuine evo TDO5s (or chineese knockoffs), you just need a bit of investment in adaptors.
    Steve
    You do realize the tranny brace is welded inside the bell housing, and has nothing to do with your heavy duty pressure plate or motor/tranny mounts right?
    If anyone is interested in learning about it search it, or pm Ray Papanya. IIRC it's recommended if launching with 450 awhp and up. (or 500)
  5. #25
    erm
    it's not exactly a trans brace...or that's not your best way of describing it...it's kinda a beef up plate that's welded into the bell housing, the trans brace sounds like the transfer case brace...which I believe does nothing (since by the time it's under load the case itself would need to have broken)
  6. #26
    Ray Papanya)
  7. #27
    There are a couple versions, but yeah that is what I was talking about. My bad, it is the tranny bell housing brace. Even the transfer case cage has nothing to do with mounts or pressure plates as mentioned. In fact just the opposite. The more solid your mounts, the more stress it puts on the drive train during a launch. I.E. nothing flexing to dampen the torque.
    If interested here is a good read. Info about power and which housings are found in there, but may have to read some to get to it...
    Pampena Motorsports Bellhousing braces CLEEEAAN INSTALL! - Page 3 - 3000GT/Stealth International Message Center
  8. #28
    LMAO, Hey I'm not Italian! I can't speak or spell it!!!!!!!!!
    P.S. Don't show him! I may need a deal some day! lol
  9. #29
    Australia verified
    Melbourne, Australia
    LMAO Mick dropping down the GIF, never seen you post one, new years resolution hey? haha...
    Kangaroo
  10. #30
    lol, I was looking through the smilies list saw it and had to use it
    Picard was the best captain.
