Only input I can add is when I was shopping and comparing BAS vs DLI, Matt M suggested DLI because boost-a-spark would blow ECI fuses at the most inconvenient times. Like impromptu race. So I told him to write up my order for DLI. Didn't have any, couldn't get any and sent me to another vendor that had them in stock. That told me all I needed to know. Bought a DLI.
I've been running my DLI on both 6g72 and 4g63. Not hot-wired Stock coils for the respective engine. 6g PTU on both. Donniekak gets more out of his stock 4g coils without an ignition amp than I do. Could be PTU difference since he runs 4g PTU or it could be worse wiring in 3S to coils.
DLI has done the trick at up to 38psi, .022" gap, (600+ awhile thru auto) and even lights off at low 10s afr on E85.
I'm not even a mechanical engineerso have no idea how or why DLI works but it does, for me. I'll let you guys know how 40+ psi works in the spring.
) and some of this is over my head... but I can pull the concepts out from what you all are saying.
