Jim,
In the photo, is that the power supply on the right hand side, with the 2 DMM leads attached? It looks like some sort of eval board? Or is that something custom? The only reason I ask is that the eval boards I have used for testing power supplies, did not have very large capacitors on the output. You might be able to clean up those traces on your scope by using larger capacitors.
Unfortunately I don't have access to a high voltage probe so I can't risk exposure to the flyback voltage. The gain of the part you reference does drop off however from the other curves it looks like plenty of gain is still available. And that particular part still has a very low Vce deep into saturation.
@ jimvr4 my testing was using the 12vto20v box as I linked.
A DC-DC box, a good diode and the second fuel pump relay would make BAS that would get you home if the DC/DC converter failed.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
I wonder about increased stress on the PTU & coils if running 18 - 20V and higher current all the time. A DD probably doesn't need that a lot of the time. I like the idea of switching it on via ecu or some other control only when needed.
I was worried about running that voltage all the time. Hence the bsa.
Btw i recommended increaseing the limit to 90% and the dwell time by 25%
