Page 718 of 892 FirstFirst ... 218618668708716717718719720728768818 ... LastLast
Results 7,171 to 7,180 of 8916
  1. #7171
    if you get a clean piece of steel you don't need to sand it, just oil or wd40 it once in a while. These have been here for a year:
    The millscale or whatever actually prevents rust.
    up close the surface after dragging transmissions and whatever over it for a year:
    I have one back at my rental place like this that I know he hasn't oiled since I left a year ago and it is still clean.
  2. #7172
    Sep 2012
    Decatur, TN
    Not clean unfortunately, there's some rust on it. May be able to get it off with steel wool or Brillo pads or similar.
  3. #7173
    Never finishes any verified
    Wake Forest, NC
    I actually used a sheet of linoleum floor on top of my workbench. I wanted something somewhat soft to work on stuff and it had to be easy to clean. I keep a piece of 3/4" plywood, sheet of foam board and a sheet of metal "all 2'x2'" under the bench that I place down when needed. Works great!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #7174
    Sep 2012
    Decatur, TN
    Right now it has like 1/2 particle board or OSB On it and it basically has started to bend. So if this works out, probably leave it bare.
  5. #7175
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Quote Originally Posted by lawdogg View Post
    Finally finished up the last SS line / speed bleeder and bled ATE formerly blue now gold into the system.
    Found out I have 2-3 oil leaks, a p/s fluid leak, and seeping trans casing seals. Woo!
    I always get so excited when I am about to work on my car after a long break... Then I get underneath it and see the rust and oil leaks which is a nice start to the cry fest that usually ensues.
  6. #7176
    Mar 2013
    SL owner since Jan 2010. VR4 owner since Sep 2012
    Riverside, Cali
    Replaced the fuel filter, FPR, oil cap (w/a Ralliart one), radiator (3sx single pass), steering wheel (Momo w/quick release hub), BOV (Greddy type S), bunch of coolant lines and heater hoses, various gaskets, tested and clean injectors, rebuilt the TB (thanks DBest!), replaced all the couplers with new ones, deleted clutch booster and window washer bottle as well as other minor things, replaced all worm clamps with T-bolt clamps, powder coated PPE FMIC pipes dark red and chrome. I think I'm missing other minor things. Took a while because of school and work u.u. But its finally up and running.
    Oh and replaced the center console on the SL :P lol.
    1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
  7. #7177
    Jan 2013
    Toronto
    Started the tear down to replace my cracked plenum. Adding this one, the new powered rails and will pull the injectors to put new o-rings on.
    Shawzy44
    18" Saleens, Lat42 Mud guards, TechWorks ECS controller, ECS struts w/ TEIN S springs, RetroSpec side splitters & front lip, Dejon SMIC and pipes,Jesters MAF, Mishimoto Aluminum radiator and fan shroud, Jesters Flash ECU, LCDBC w/ TFT logger, Boostmore 15G Turbos, 3SX downpipe, racepipe, 3" Quad tip exhaust, Setrab oil cooler, AEM FPR, Supra fuel pump, FIC 650 injectors, Fidanza flywhee
    Garage: http://www.3sgto.org/garage.php?do=user_garage_view&id=4247
  8. #7178
    San Francisco
    Hahahah, that's it to a T. That exact feeling of disappointment ... every time.
    Support NG!
  9. #7179
    What you guys don't like getting excited to fix one thing only to be reminded there are 1000 other things that need done?
    On a related note, after relacing my shift boot/ knob and realizing how gross my interior is I bought a nice set of stock cloth seats to replace my beat leather ones today.
  10. #7180
    Key Largo, FL
    Pulled the wheels to clean the wheel wells and spray some tire shine in there. Getting it ready for a car show on Sunday. Do judges even notice when you've cleaned and detailed your wheel wells?
    2013 NG: 1st place, FWD Drags
  • History
  • Information
  • Groups
  • Events
  • Resources
