Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: My Positive Exp Tuning AEM EMS S2 on Stock Turbos/Fuel - 313//337
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    Thumbs up My Positive Exp Tuning AEM EMS S2 on Stock Turbos/Fuel - 313//337
    I usually keep my more mild tuning updates to our regional board, but I felt that this build has had a pretty cool outcome thus far.
    The owner, Rob, was referred to me through another client/friend in SoCal. After seeing the results with "DuTTch" Mark's VR-4 [560AWHP @23lbs on AEM], he decided to hit me up. I knew that I could not pass up the opportunity to tune a Series 2 from scratch yet alone with a stock turbo and stock fuel car.
    Needless to say, I was determined and very much prepared. I was already on my toes from doing multiple GReddy/Link/ECUFlash tunes and such this year with local 3/S, Evo, and DSM cars. The results absolutely surprised me, and I can honestly say that the car drives leaps and bounds better than it did on stock ECU/MAS!
    Full boost by 2.8k, crisp DFCO, lean cruise, and she looks/sounds/performs plain mean! The only downside was that I quickly realized how limited I would be from the stock fuel system - completely tapped out! I was amused to learn that shortly after receiving the car back, he had wasted no time in acquiring GReddy 720cc injectors and a Walbro 400lph FP yeeee!!
    "313AWHP is the final number - for now! This is exactly what I was aiming for on stock turbos, stock injectors, and stock fuel pump. The gains are roughly +38//22 at the same 1bar boost with pre's hollowed and 3SX DP added along with fine-tuning the AEM of course. I am definitely content despite not having more fuel to work with.
    For the record, peak KNKV was ~1.09v =]"
    The next possibilities include more boost on Pump-91, 91/100 mix, or Pump-E85 regardless of stock or upgraded turbos. Things will continue to get more interesting to say the least though!
    Stay tuned!
    -ALan/BTS
    //edit//
    2015 UPDATES >> Page 3
    Nov 2006
    Chula Vista SD, CA
    Talking
    Oh! I almost forgot my pre-celebratory breakdance 3/S picture
    Gotta love the S2.
    Nov 2006
    Chula Vista SD, CA
    Gotta love the S2.
    Yess'r! Chris H. and I have been joking back and forth via FB comments about live tuning being the best perk of all; it really is though.
    I don't bite
    Southern IN
    Good shit! You know my opinion on AEM S2
  6. The Following User Says Thank You to familyMAN For This Useful Post:
    Nov 2006
    Chula Vista SD, CA
    HAHA ya damn right I do brotha
    BTW! Did you end up going with a Holset over FP? I could have sworn that you ultimately decided on an HX40. The reason I ask is because I miiiight be taking in a local's built 8.5:1 2.0L with the 6-blade HX40. It VD baselined around 350+ on Link v3 lite in SD and needs a complete retune. I was curious to hear your experience and what kind of powerband+boost curve you are/were seeing for comparison.
    The underhood madness of a large turbo 2.0L 4G63T. Break-in has been completed, and a few items will be addressed before the next step, such as FP intake pipe, sealed OCC w/ vac, wiring, etc.
    Yes, I can [and just did] derail my own thread LOL!
  8. #7
    I don't bite
    Southern IN
    I have a 7blade 70lb/min HX40 on the shelf. Still rockin the 14b for now until I gather the final pieces to build the spare block into a long rod 2.4. Just need a 7bolt 2.4 crank and torque plate and it can all go to the machine shop this winter.
  9. #8
    I can so see myself maxing out my 13G's before stepping up to DR750's. Thanks for sharing.
  10. #9
    I don't bite
    Southern IN
    Curious...How much boost for the 350hp on the 2.0 hx40?
  11. #10
    Nov 2006
    Chula Vista SD, CA
    Very welcome and thanks for commenting! I believe it was Saf from France that pushed 13G's to 430AWHP on Pump-E85 and AEM EMS.
    [I just double-checked to confirm and yes, I remembered correctly!]
