Results 1 to 10 of 10
Thread: Changing evoscan logging order
    I figured out how to make it hide the stuff you don't use when it makes the log but is there a way to change the order of the columns it makes? I've searched and tried changing the order they are listed in evoscan.
    One fix at a time verified
    Kansas
    Hit (Ctrl-U) or (Ctrl-Up arrow) to move the logged item up. Hit (Ctrl-D) or (Ctrl-Down arrow) to move it down. That should change the order for you.
    To change the order in which it makes the excel file
    You have to edit it in excel as far as I know.
    Kansas
    You can change the order they're listed in evoscan and that outputs it to excel. I've done it before. I just don't have the program with me or a car to verify it on. Move all of the datalogging items up to the top in evoscan. This will get rid of the white empty columns in excel. Take and move the datalogging parameters up or down if you want a specific one in a different spot as you scroll to the right in excel. It should be easy and straightforward.
    You get rid of the columns not being logged by editing that parameter and changing "LogHide" to true. As far as moving them up and down the list that is the first thing I tried and its not changing the order of the columns when it makes the excel.
    August 2010
    Chicago
    If i remember correctly, just drag the item to the top of the list on evoscan and it will show up in the same order on the excel file.
    34XXlbs..
    Well then either mine isn't working for some reason or they fudged it up in the update
    Turbo Timebomb
    Elkhart, IN
    subbed!
    I found the answer to this playing with it yesterday. You must relocate the rows with "Display only checked items" off then when you turn it back on they will be in the correct order.
