Page 667 of 892 FirstFirst ... 167567617657665666667668669677717767 ... LastLast
Results 6,661 to 6,670 of 8916
  1. #6661
    August 2010
    Chicago
    Quote Originally Posted by Ange View Post
    bucket CF seats ~80 lbs
    A/C delete ~45 lbs
    CF hood ~45 lbs
    =~170 lbs
    not that easy. Stock driver and passenger seat combined come in at 112lbs. Are you saying that 2 cf seats WITH rails and hardware will weigh just 32lbs? Seat brackets are 13lbs alone both. Thats what I used to think also...more realistic savings are in the 50lb range. I saved 45lbs.
    AC delete is closer to 30lbs.
    CF hood won't save you 50lbs either. Stock hood is 57lbs. CF and FG variants are in the mid 20's range. So a savings of about 25-30lbs. Total realistic savings of your list are closer to ~100lbs.
    34XXlbs..
  2. #6662
    August 2010
    Chicago
    You guys must live in St. Louis also, where gravity is more than elsewhere.
    nope...we have realistic weight numbers...most people grossly overestimate their weight savings.
  3. #6663
    drives with Drivers' gloves.
    Maryland
    not that easy. Stock driver and passenger seat combined come in at 112lbs. Are you saying that 2 cf seats WITH rails and hardware will weigh just 32lbs? Seat brackets are 13lbs alone each. Thats what I used to think also...more realistic savings are in the 50lb range. I saved 45lbs.
    13lb seat bracket, that sucks...
    I'd be rather surprised if my Sparco CF S-Light Seat and fixed aluminum bracket (perfect height - head not all up in the roof) weighs more, or much more than one of those 13lb seat brackets.
  4. #6664
    August 2010
    Chicago
    I weighed it..corbeau seat bracket. Oh you know NVM...it was 7lbs..not 13..
  5. #6665
    The racetech head restraint seat I want is 12 lbs, my custom brackets are less than 10 because I don't use sliders for headroom, probably closer to 5. But a seat like that isn't really good for street use.
  6. #6666
    Jun 2011
    Sweden, Gothenburg
    I'm changing to bucket seats. Will weigh everything and get back at you.
    A/C delete is 45 lbs confirmed by many.
  7. #6667
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    My carbon hood weighs 5.5 lbs without hinges or pins. Stock weighs 55lbs without hinges or shocks. It will be a 50lb savings when I eventually install using stock hinges but deleting shocks.
  8. #6668
    Man vs 3/S verified
    Kingston, WA
    Wow, thats a bunch... adding a hood to my "want" list
    From the phone.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  9. #6669
    i like the weight. i like the look. i hate the fit.^
  10. #6670
    Man vs 3/S verified
    Kingston, WA
    Thadd thats one of my things too. I dont want a hood unless it has 105% stock fitment. Probably why I wont ever get one :/
    From the phone.
