Stripped the longblock on Sandstone... Pulled the racecar out and warmed it up. Went to the carwash and got a hand-wash, wax, and buff. Was asked to do a burnout so pulled off the lot and dropped the clutch off Two Step and engaged NLTS. Fish tailed across 3 lanes and spun 360. On road slicks smoking on all 4, smoke billowing out the fenders and sped off. Standing ovation and wave from the detailers at the carwash in the rear-view. Cracked a little smile on the way back home and parked the car back on the tire guards in the garage.
Late present showed up
Sent from my SPH-L720 using Tapatalk 2
Black 1994 Mitsubishi 3000GT VR-4
Billet DR650s, PRO efi 128 ecu w/ flex fuel, 52mm CAN gauge, FIC 1100CC injectors, Ported heads, Parker SS Fuel lines, Walbro 416lph e85 fuel pump, Maximal solid motor mounts, Spec stage IV clutch, Pampena bellhousing brace, Tail BOV, MSD wires, Enkei RZ-5 w/ Michelin Pilot Super Sports, Skillard front splitter
I finally cleaned it up again & got some Shark Hide protectant on some of my polished aluminum parts...Replacement seats should be here by Friday.
tested some things:
sorry the pictures are awful, will try better later
Does it work well is the question?
well evoscan connects just fine and I read from the ecu no problem. Connection never dropped out or anything like that. battery lasts 8+ hours.
I would've tested a write, but this battery has been sitting since june without charging.
Most excellent! What are te specs again? I know you posted them somewhere, but lazy!![]()
