Page 666 of 892 FirstFirst ... 166566616656664665666667668676716766 ... LastLast
Results 6,651 to 6,660 of 8916
  1. #6651
    Key Largo, FL
    Kind of sad, but I haven't driven the Stealth since getting back from the NG, other than getting new rear tires put on, which was a 2 mile drive each way. Yesterday, I pulled it out of the garage and cleaned it up some, and installed some LED lamps for my rear plate. I need to do an oil change once I have some time and money, but the main reason for not driving it is the almost daily afternoon showers we've had this year. I'm not taking out in the rain unless I have to.
    2013 NG: 1st place, FWD Drags
  2. #6652
    Sep 2012
    Decatur, TN
    I left the jack unger the pumpkin, and she pulls right out.
    Well I've got to get the ABS sensors undone (may just cut them since I'm deleting ABS) and disconnect the AWS lines. Looks like a lot of shit has been ziptied back here (probably previous owner, doubt OEM would use zipties like that) so having to go slow and make sure I don't destroy anything I'll need later. On the fence about deleting AWS while I'm going to have it all out just so that it can't break on me later.
  3. #6653
    Jun 2011
    Sweden, Gothenburg
    Got the rear subframe dropped, working on trying to get all the little shit disconnected. Decided to leave the wheels on so that I can roll it out from under. There is going to be a lot of refurb/rehab going on back there..Lots of rust and crap.
    take it to someone who can sandblast it, then repaint yourself.
  4. #6654
    LA .. as in Lower Arkansas
    About 6 weeks of work to to the SL, total knee replacement surgery does that to you ....
    Window seals
    Driver side electric window assembly
    Glove box lock - thanks Hans
    Got the AC fixed, the dash light would start blinking shortly after engaging, sometimes it'd work for extended periods , sometimes .. 3 seconds. Now .. it stays cold
  5. #6655
    I weighed my car at my friends shop. He needed to buy some scales to weigh pallets, and opted to buy car scales instead as they cost a tad more. He's never corner balanced anything. I was more or less using them as a scale.
    I definitely thought my car would weigh less with all the weight loss stuff I did(rear tow hooks, no front crash bar, no fog lights, no active aero (99 stuff), RPS LW flywheel, no spare tire, no jack/tools, aws delete, abs delete, charcoal canister delete/vac reduction, cruise delete, clutch vacuum canister delete, lighter exhaust, carbon fiber one piece driveshaft, lighter wheels - 18x9 enkei rp03's ) I was thinking the car would weigh around 3500 and was 131 pounds off. I do have a 10" corner sub box in the trunk and mdf floor back there. I'm going to weigh some stuff individually and see what I could pull. I wanted the car around 3300.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  6. #6656
    August 2010
    Chicago
    How much gas did you have in the car?
    I Weighed mine a few months back...3940 fully loaded.
    Full tank e85-128lbs (19.8 gallon tank + 6.5lb/gallon of fuel)
    Driver-153lbs
    Spare/Jack-30lbs
    Misc crap in car...laptop/screws/glovebox-10lbs
    So with a few gallons of gas with no driver dry weight was right at 3640. Since then I have gotten new wheels and seats. Seats dropped 45lbs. Wheels maybe 5-10lbs. I'm right at 3580ish....next is a hood, AWS delete, Airbags plus airbag computer and I'm probably going to dump my front crashbar and also rear tow hooks. Should net me another 95lbs.
    3300 almost seems like a pipe dream. How do you plan to drop another 300ish lbs?? Honestly I wanted 3300 initially too....now look at my signature...reality set in..
    34XXlbs..
  7. #6657
    It was half way in between 1/4 and a 1/2, so 3/8 a tank. I guess that would make it 48 pounds in fuel and bring car down to 3583 pounds. Granted I need fuel in the car to drive
  8. #6658
    You guys must live in St. Louis also, where gravity is more than elsewhere.
  9. #6659
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by fastfalcon94 View Post
    bucket CF seats ~80 lbs
    A/C delete ~45 lbs
    CF hood ~45 lbs
    =~170 lbs
  10. #6660
    Dayton, Ohio
    Yanked the IAC out of the Spyder and put it in the Stealth (it wouldn't hold idle for shit).
    Ordered a new IAC for the Spyder from RockAuto. About $80 shipped.
    Put the battery from the Spyder on a maintainer while waiting for the new IAC.
    Meh....
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
