Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: I think my water pump is going bad.
    Yes, but not always does it happen to create such drastic results.
    Mine did start to sound similar to what you describe. It sat for 3 yrs before I bought it with 8k on a 60k. 3 weeks into owner ship the sound appeared.
    The pump froze at 55mph the idler self destructed, the tensioner followed. The crank teeth stripped the belt smooth. I assumed carnage, but valves and pistons survived unscathed!
    Luck, maybe! I would definitely figure it out before finding out the hard way though...
    Texas
    I just hope to get the pin back in my tensioner to save myself another $75. I am replacing the pump next weekend when I get some money in.
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    If you need a new tensioner, I have one with ~8k miles on it...You should be able to get the pin in using a vice
    Texas
    Quote Originally Posted by terrets View Post
    Hopefully I can get the pin in before pulling the belt off.
    December 2009
    Fox Cities, WI
    Hah good luck.
    Waterpumps often go bad because the headgasket has already failed, there's an increase in pressure in the cooling system, that makes the pump seal fail, water gets into the pump bearings, it seizes, the cambelt melts, 24 bent valves.
    Steve
    I think you're smoking the good shit again.
    Water pumps fail due to age and usually the bearings failing. If a headgasket were bad, he'd know it.
  7. #17
    Texas
    I was gunna say, I compression checked it at 155psi. No water in the exhaust and it doesn't spray out of the thermostat when the cap is off and I am cranking the engine.
  8. #18
    The knocking you are hearing sounds like it could be a timing belt slap from a possible failing tensioner.
  9. #19
    Texas
    This is something I am going to check. But if that were the case, shouldn't I hear it more on the front exhaust cam than on the water pump? I mean the water pump is LOUD with a stethoscope, and the cams are fairly quite, even on the cam caps, not the valve cover.
    Also, I have turned it on and off several times to get the motor in different positions, even turning it backwards slowly by hand and forwards as well. I don't ever see any excessive slack in the belt. I also have had a tensioner fail completely and some how caught it before it messed anything up and it doesn't sound like this, but then again, if it is starting to fail, it could sound different.
  10. #20
    You dont ever want to tun the engine backwards. You are almost guaranteed to make it jump time like that.
