I've got to agree with Stealthee on this. Not only is turning the engine backwards dangerous but its pointless as well. When you turn the crank clockwise it pulls the belt down from the fixed idler pulley and rear exhaust cam allowing the tensioner to maintain it's normal position. When you go counter-clockwise you pull the belt against the tensioner pulley which then pushes in against the tensioner, collapsing it. Even if you did find the belt loose after rotating backwards all that would mean is that you pushed in the tensioner. The only real way to test this is to rotate the engine around a couple of times (CLOCKWISE!), reset to TDC, and measure the protrusion of the tensioner.
Let me put it like this, I have about 7 years experience working on these cars. I have seen just about everything go wrong on these that can go wrong, including a transfer case lock up on me @90MPH.
My coolant levels haven't changed a single bit, besides moving from the res to the main system and vise versa. Compression check is higher than a normal engine, this is because of 8.5:1 and about 1300 miles on the engine. No water comes out of the main system with the cap off when cranking, or running the engine until it gets to temp. My temp stays just under halfway, as it has for the almost 5 years I have owned the car. No leaks, no pressure besides what should be there from hot water, no coolant in the exhaust. I highly doubt it is a head gasket issue.
I am not saying it isn't safe, but I trust my knowledge and my skills to do safe things on cars. I would never recommend a normal person to do this. You can do what you want to, and I'll do what I want to. Regardless, there is 0 slack. This still doesn't mean there wont be slack under a load in first gear when the engine is really torquing.
Oh I know, and I'm not trying to pick a fight, but you've got to remember "normal people" read these posts too. Plenty of folks have gotten into trouble turning the engine backwards and you wouldn't want some one to try it because Blindmist has done it "a 1000 times".. Besides you've got to expect some push back when you go against conventional wisdom.
Like this:Conventional wisdom would say that engine torque has little to do with t-belt tension. The amount of force working on the belt would be whatever it takes to turn the pulleys. Increasing speed might increase the load on the belt, as it takes more force to move things faster, but how hard the engine is pushing (against the vehicle's weight) has nothing to do with itThis still doesn't mean there wont be slack under a load in first gear when the engine is really torquing.![]()
I, sir, love your rebuttal. You need to further comment on the Legalization of Cannabis thread.
Anyway, I was more referring to the torque from the crank gear on the belt. I know there is more pressure on a belt. I am just not sure how much an if it would make a difference. Although, I am fairly certain the tensioner is good because it IS brand spanking new and I had the engine on a stand for a long time and checked it over and over. Like I said, I have had one fail, I wanted 0 chance on this build. BUT STILL, there is no 100% guarantee that the tensioner isn't the problem until I really get down and dirty with it.
Comment further? I don't believe I've commented at all in that thread. If I had it would be to point out that anything I can grow in my backyard is just God's little gift to me...You need to further comment on the Legalization of Cannabis thread.
Funny, it just pisses my girlfriend off...I just like the way you argue!![]()
