Page 109 of 135 FirstFirst ... 95999107108109110111119 ... LastLast
Results 1,081 to 1,090 of 1341
Thread: CoopKill's Mistress Makeover Thread [Pic Heavy]
  1. #1081
    5 minutes
    Sent from the Man Cave!
    *\( ^o^ )/*
  2. #1082
    Home Sweet Home!
    *\( ^o^ )/*
  3. #1083
    As he mentioned clearances are tighter.
    *\( ^o^ )/*
  4. #1084
    The Panda Not Verified
    Washougal WA/Portland OR
    Home Sweet Home!
    *\( ^o^ )/*
    i see see what you did there.
    Denso Supra fuel pump, RC 750cc fuel injectors, AEM Fuel pressure regulator,​
  5. #1085
    Wut?
  6. #1086
    pretty big ring gaps
  7. #1087
    I believe that is the info that came with them. I will be crushed if I have to tear it down, and replace them... Again!
  8. #1088
    Oh, I think it will run okay, but I would expect seeing closer to .020. It might just use a little more oil, but you definitely won't worry about the rings butting and breaking.
  9. #1089
    Medford OR
    I agree... Run it, it will be fine. I would have run them tighter, and usually run the 2nd ring equal or slightly wider than the top ring, (there are differing theories on that which could spark endless debate) but yours aren't wide enough to be a problem...
  10. #1090
    Wut?
    Just edging out the monster block form the picture! You didn't want her to steal the spot light.
