Which springs were those?
AVO springs which are pretty well known and good ones over here (usually !)
tried to stab the transmission again, this time with the help of my wife. it doesnt wanna go
Probably not, as long as I lay there I am good lol, its getting up and moving makes me dizzy, I take my time. Tommorow Iam dropping the tranny again and putting in the clutch alignment tool make sure the clutch plate still lines up.I like your idea but its lining up pretty good except the input shaft lol.
i cleaned and cleaned and cleaned. well, the first two cleans were actually on saturday. the last was sunday, and nothing as of yet today.
awhh, you did it!//oheay fuck you
_isiah
I did some more sanding & the final polishing on my lower intake plenum. I then finished it off with some Shark Hide metal protectant to seal it all in.
today I changed the horn buttons on my 95 base and rehooked up the stock horns. its working again woohooo
Ordered a set of wheels this morning. this afternoon I changed the oil and drained the catch can (talk about nasty, at least i know it works).
