Page 14 of 40 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 391
Thread: Big Single Build
  1. #131
    Eagle Lake
    damn buddy, looks like you're coming right along.
  2. #132
    Jealous of your pile-o-parts, Kev.
  3. #133
    Andover, MN
    Ordered Maximal Performance Solid Motor mounts and Brownline Digital Torque Wrench.
  4. #134
    Andover, MN
    So I had a post on the other forums regarding the wastegates leaking on the plunger side, so I thought I'd explain what some of the parts in the wastegate kit are.
    You have the basic wastegate:
    Note the surface of the ring is opposite that of the plunger in the wastegate as if to make a seal. However when you place the ring in this flange, it hits the plunger:
    You need to put a vacuum pump on one of the nipples on the wastegate and pull the plunger back with vacuum. In my case, I was testing the amount of vacuum required to pull the plunger back:
    Note, this is what the ring looks like when the plunger is down:
    Then insert the ring with plunger up:
    If you have a collection pipe like I do with the flange already welded on, you will want to insert the gasket and put your flange on and tighten it:
    Now you will have the wastegate sealed and it should barely leak any air, a little is OK. You can pressure test it by hooking it up to an air compressor. I haven't pressure tested it on the valve side yet.
  5. #135
    Andover, MN
    Here's a really good guide on installing external wastegate:
    http://www.treadstoneperformance.com...nstall-112.pdf
  6. #136
    That's the same type of gates that I'm using as well. They do work great. The gaskets however cook up and blow out fast. I made a set from sheet copper that hold up much better than what they come with. Thin sheet too, cut the outter portion with a pair of scissors.
    www.stickyvinylgraphics.com
    Custom Stickers & Graphics
    www.chumpcar.com
  7. The Following User Says Thank You to Erron Spalsbury For This Useful Post:
  8. #137
    Andover, MN
    Quote Originally Posted by Erron Spalsbury View Post
    Good tip, Erron, I was thinking about that too, these ceramic looking gaskets look like they will get brittle fast.
  9. #138
    Andover, MN
    Ordered Synapse Synchronic BOV.
  10. #139
    Quote Originally Posted by Boost4VR4 View Post
    Yes sir. Mine came with those and if memory serves they lasted about 20 minutes on the track. I think they just burn up, crack, then blow out.
  11. #140
    Andover, MN
    I should be able to cut anything I want now that I have a bandsaw in the garage. I can cut out some meaty wastegate gaskets.
