Page 4 of 40 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 391
Thread: Big Single Build
  1. #31
    Frontline Fabrication verified
    Morgantown, WV
    Well I guess this is much better view of the flange you can see the contour into the LIM ports better.
    we have a HAAS VF2 mill that we do our work on here at the shop
  2. #32
    Andover, MN
    Quote Originally Posted by Amphiron View Post
    That's not even going to be close to accurate enough if you want to all to fit together like OEM. You need precision measuring tools if you want to provide something a machinist can use. I'm sorry but if I bring a piece of ply wood into work I will get laughed at. I'm also not sure how we are going to cut the tapered hole, usually that stuff is cast from a dye. It might even have to be done on a older mill at work where you can set the angle of the head. You are gonna need a good print with a section view etc.
    The reason why I thought to start with the plywood is because you can have it traced on an aluminum block and the piece can be cut free-form which is what I am thinking you're going to need to do since this piece is so complex.
  3. #33
    Morgantown, WV
    you have a PM Boost
    '95 Passion Red RT/TT
    www.frontlinefabrication.com
  4. #34
    Andover, MN
    I may take a different approach to this intake issue, I can use the existing intake and go water/air IC and probably spend less money on the intercooling setup...
  5. #35
    Andover, MN
    Picking up a 2nd SOHC engine to build on.
    Here's the updated parts list:
    https://docs.google.com/spreadsheet/...rbnU1bGc#gid=0
  6. #36
    Andover, MN
    Revival of this project starts today!
    Picked up used SOHC engine. Tonight I will pull it out of the truck and put it on an engine stand and start the teardown!
    Since I have an engine in the stealth already, in the coming months, I will be able to fabricate everything on that car with the engine in place. The list hasn't been updated yet, but I will be going through it again and making adjustments. Pictures will be in order very soon.
  7. #37
    Andover, MN
    Oh... there is a few more things up my sleeve in terms of this build...
    I think I am going to build a single connector engine harness and relocate the main fuse box in the car.
    The following items will get deleted:
    A/C
    Evap and EGR
    Interior
    So here we go with the real stuff. I picked up an engine from Josh Mitoska from 3000GT/Stealth Supply. I didn't get an NA engine, I picked up a SOHC engine. This is a SOHC turbo build, so all the haters and naysayers and people questioning this build, keep the comments to yourselves. I haven't torn down an engine before, so this will be both a first and a new learning experience. I have been fortunate enough to have only worked on engines from the heads up.
    So I got to work on this engine. The engine was pulled from a car that was a parts car and the engine had a blown head gasket. Honestly while tearing this engine down as far as I did, most of the components are in good shape. So here's what we have to start with:
    Off comes the Throttle body:
    IAC and TPS pulled injectors are not for this car, they are for a Jaguar XJR:
    Components off the back of the intake plenum:
    Plenum Pulled:
    Lower Intake Plenum pulled. All of the LIM head studs were bent causing a lot of grief during the removal process:
    Pulled the rear valve cover off to basically check condition of everything, seems to be in working order. Rotated the crank a few times and the valves visibly move normally:
    Pulled the timing belt off and worked on removing the water pump, got stuck on an issue removing the upper timing back covers, so will need to remove cam gears to gain clearance around cam sprockets to bolts behind cams, namely on the rear cam:
    It also looks like the oil pump seal blew at some point because it's quite dirty.
    All the stuff I removed:
  8. #38
    Good progress so far
    Andover, MN
    Alright, made some more progress tonight. So the goal was the pull the heads, and that is what I did:
    Here's where the low compression issue was:
    For the most part, everything looks good, cylinder walls are smooth.a
  10. #40
    Andover, MN
    OK ladies and gentlemen, I want to put a status update out there because there will be quite a bit of insanity going on with the car.
    Keep in mind with all of the work going in to this project it really is not all in vain. While I really want to be unique and attempt to get a single turbo setup bolted on a SOHC engine and go fast, it really is not about that. I want to build something that is challenging. After all, I really don't have a ton of money tied up in this car, and the existing engine in the car still runs fine. There are many reasons why I didn't pull the engine out of the car and rebuild it, but I won't list them here. Thanks to Josh Mitoska for pulling this engine last minute before the NG and for giving me a killer deal on the entire engine.
    So here's what I am after with this car. I have always liked what NRE does with their engines in terms of the harnesses they build. They build single connector harnesses, so, one of the things that I do plan on doing is to build a single connector engine harness that disconnects near the firewall. One of the reasons I want to do this is to clean up some of the wiring that gets routed every which way across the engine. Also I really dislike having to disconnect all of the plugs off of the main harness just to yank the engine out; it would be much simpler to unplug one plug and yank the engine out with all of the components still plugged in.
    I also never liked the idea of the main fuse box under the hood of the car. I mean I get why it's done, but I would much rather have it relocated inside the car. So that will be taking place as well, this will be a major undertaking as the main fuse box wiring is kinda a cluster.
    Also, since I am really turning this into because racecar status, the interior panels will be coming out. The door locks and power window switches will be relocated to new switch panels in a modified center console and the center console will also be fitted with switches for manual override to any components that are powered by a relay. My thought is to retain existing relays, however install switches that allow me to manually override the relay in the event a relay goes bad or other issues exhibit their ugly head. The interior lighting will go away, the unnecessary electronics will go away, ABS will be deleted, A/C will be deleted, all of the carpc stuff that I originally planned for the car will be put in a different vehicle.
    So what are the plans for the engine?
    Well for starters:
    Bored .030 over
    Beehive Valve Springs
    Wiseco Forged Pistons
    Ninja Performance Chromoly Connecting rods and wrist pins, rings
    Webcam 272 cams
    1000CC Injectors
    Air to Water Intercooler setup with external heat exchanger, pump, icebox, piping
    Custom VBand intake piping
    Borg Warner Twin Scroll Divided T4 Flange VBand Exhaust and compressor side< This turbocharger is MORE than sufficient for this engine.
    Oil Cooler and lines
    For now, that is the sneak peak in terms of the build. More to follow.
