Page 13 of 40 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 391
Thread: Big Single Build
  1. #121
    Andover, MN
    Oh boy, it's time to do work, son!
    Here's the latest shipments that arrived today:
    Ninja Performance Chromoly Forged Steel Connecting Rods:
    Full Engine Rebuild Gasket Set:
    Accessory Belts:
    Be prepared to be blinded by 3SX harmonic balancer:
    60k/120k Maintenance. That Oil Pump came straight from JAPAN!:
    Knock Sensor bracket and bolts:
    Throttle cable without cruise:
    External Wastegate with dump tube will be showing up tomorrow.
  2. The Following User Says Thank You to Boost4VR4 For This Useful Post:
  3. #122
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    nice~!
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  4. #123
    Looking good!
  5. #124
    You're going to hate that non-cruise cable when you unpack it, lol. it's loooooooong.
  6. #125
    Prezzies!
  7. #126
    it's loooooooong.
    That's what she said
  8. #127
    Sweet!
    Water pump?
  10. #129
    Andover, MN
    Water pump?
    Yea the water pump is in the upper right corner. Oil pump is below that.
  11. #130
    Andover, MN
    Ok so I got the wastegate today.
    They shipped two on accident, so I am being a gentleman and sending the one back.
    CX Racing 38mm External Wastegate with 16PSI spring:
    Two Wastegates!:
