Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: Guaging Interest Excessive Manufacturing Intake Plenum GB
  1. #51
    I don't bite
    Southern IN
    These manis have been sold on diamantes for a while now. I'll keep searching for a graph. I would like to see what their curve looks like to make sure something weird doesn't happen that is unexpected.
  2. #52
    The more I look at it on the car, I think I will have to take the car to him, and pull my plenum so the angle can be found to cut the NA plenum. We need to remove ~2" which puts the tank a couple inches short of centered on the highest section of the valve cover.
    The options are to 1: add a spacer, 2: cut to an angle, or 3: cast a new tank to accommodate the valve cover. Casting a revised tank may not be that expensive, I will inquire. Thoughts?
  3. The Following User Says Thank You to CoopKill For This Useful Post:
  4. #53
    Can we just get the 3.5 liter bolt on plenum with Q45 TB bolt pattern? (Passenger side)
    Can do my own porting and gasket matching.
    Mods
    OBX long tube headers, Flow master single 3" in with dual 2.5 outs. VR4 runners with 2 liter plenum, port matched lower intake, stage 3 or better race prepped heads with 1 mm oversize Rev valves, Rev race dual springs and Rev keepers, Delta/HKS 272 cams, 3SX adjustable cam gears, 3.0 Cobra Mustang Throttle body, 3.0 LT1 maft and Maftranslater gen II, Alum. Flywheel, Spec stage 5 clutch, VR4 injectors, Wizard wires, Unorthodox under drive. IPS fuel rails w/adj FPR, Fuel loop, Walboro 255 hot wired, Hot wired single fan. Short shifter, Battery relocate. EBC front slotted rotors, EBC Yellow stuff Pads, 3SX SST brake lines, sway bars, springs.
    No IAC, NO AC, NO extra weight, VR4 ECU as of NG2011. Still 10 to 1 slugs, Nitto NT05 Competition Road Course Racing tires. Magan coil overs, 3sx adjustable rear links.
    http://www.youtube.com/watch?v=2s0I3tnGGmg
    1st place fastest NA - Drag - TXG 11 98mph, 1st place quickest NA - drags 14.773, 1st place Dyno - TXG11 229 FWHP & 236 tq, 2ND place Auto cross NA C/S- NG2011, 1ST place NA dyno - TX gathering 2010 - 229 FWHP & 199 tq, 1st place Fastest NA - TXG 2010 - 98.3 trap, 1st Place quickest NA - TXG 2010 - 14.680, 2ND place 1/4 at NG10, best NA time NG10 - 14.932- no traction, 2ND place 1/4 at NG09,
    2ND place Autocross NG09
  5. #54
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Quote Originally Posted by GTwizard View Post
    Sure can. that's the route I'm going.
  6. #55
    Crimson Jihad Not Verified
    Is there one that is passenger side? I thought all the 3.5s were driver side?
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
  7. #56
    - O - SIX -
    Colorado, USA
    Quote Originally Posted by Disrupter View Post
    The TB side is optional. Drivers or Passengers. The surge tank is reversible.
  8. #57
    The 3.5 mentioned in this thread refers to the volume of the plenum tank, and can be had in either side.
    Sent from the CaveMan Cave!
  9. #58
    Edit: Just trying to make sure I understand this all. Excessive Engineering makes an aftermarket Diamante intake manifold. We want to take that manifold and flip it 180 degrees to put the TB opening on the passenger side. They have several flanges available.
    The idea was we could just take it, flip it, and bolt it to a non turbo 3000gt lower portion (weld if we wanted), but it will hit on the valve covers because the na intake runners are slightly shorter? So our only choice is to use the diamante runners which kind of curve over that way anyways? And the flange that is on the surge tank probably gets flipped before they weld it on too otherwise the oval shapped openings to the runners would be upside down.
    I really want a q45 tb on my car with a bigger surge tank. Trying to figure out the best way to make that happen.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  10. #59
    3s NA runners welded, or bolted. Throttle body either side (exchangeable for bolted, not for welded). If shortening runners R&D is needed to clear the valve cover. (Attempting to do this) No mention of using Diamante intake for this.
    Q45 is an option, other flanges at additional charge.
  11. #60
    I am interestd. How exactly is it exchangeable for bolted? If the intake inlets are actually elongated and you flip the thing over, the holes wouldn't line up. Not that I plan on ever doing that. It's the same price for welded vs non welded? I see that JFast has already sent money. Does this mean we could order it before getting 10 people? Also does anyone know where the TB flange is compared to stock? My 90 degree IC bend is already pretty tight with the battery there. The flange isn't any closer to the passenger side is it?
