This is to see if there is enough interest to get a group buy going for 10 plenums. These are from Excessive Manufacturing using the lower half of the NA Plenum mating up to their tank.
3.5 liter tank volume.
Available in Driver or Passenger side version.
Plenum Tank welded to provided runners: (regularly $510) $412.00 (size/brand TB needed for flange size)
Options
1: Port, and polish runners. Includes gasket match runner for lower intake. $120.00
2: Weld mounting point for rear IC pipe. $25.00 (option for passenger side only)
3: Q45 TB w/TPS, and fixed 2.5" pull cable bracket. $168.00
4: Shorten runners to desired length. $75.00
5: Possible port/polish/port match lower plenum. $120.00
6: Tank cleaning runners before sending. $10.00
7: Custom TB flange made & welded on. $60.00 (will need dimensions)
Other TB Flanges are available, the Q45 is the only TB they have in stock.
Not included:
- NA runners you supply
- Shipping/Packaging/PalPal Fee (I will break down the GB fee equally, and add to shipping cost)
- Hot tanking, all runners must be tanked before I deliver to them. (I will have a price soon, or you have done before shipping)
I am making absolutely nothing on this so this must be as easy as possible to complete. All runners will be had before taking to the tanking, and then to Excessive. This will not get strung out over months just to get off the ground. If there is interest I will need ideas of when runners will be on their way here, when money will be had, and will set this up with Alan, and post PayPal info.
This will not be 100% plug & play!!!
- Kiss you EGR goodbye.
- Vacuum lines will need changed/routed.
- Throttle cable & mount will need attention.
- OEM rear plenum supports will go as well
- Charge Pipe/coupler may need some adjusting.
Name/Driver-Passenger/Options/Approx Date Ready
1:
2:
3:
4:
5:
6:
7:
8:
9:
10:
