Yeah I knew Jack was involved. But it's Jacks Transmissions instead of Jackhammer![]()
Catching up my thread with some pictures from the last week or so because we all like pics
Transfer case resealed and ready to install
Oil leaks on first startup turned out to be the rear VC
Ready for the VC to go back in
Rear VC all buttoned up
Close to finished here
Startup video! Third time and no oil leaks finally!
Amazing work.
Yes we love pics! and videos! Awesome work Jim, truly a masterpiece! I was making Mmmm Mmmmm noises like I was eating a steak when I was looking a the pics.![]()
So damn clean. Awesome work!
Congrats on the Awesome work!!!
I was sad to see the flashing ECS lights though.![]()
Me too but thankfully it was just unplugged under the cap on the passenger side. Easy fix
Put the car up on four jackstands and bled the brakes again. Pulled the rear calipers and pads and swept up half a dustpan of stones and dirt from the calipers and rear subframe.
Started the car and let it run to temp to help bleed the brakes since I have ABS. My wife took care of the pedal pushing but I noticed the CEL after she finished. I know the car runs open loop on startup but not sure when it goes closed loop. I still have to flash the ECU with the injector size (560) and latencies so I'm hoping that's the reason for the CEL.
Started looking at clutch adjustment. I can push the slave pin in just enough to clear the fork, not sure it it should go further. Have to set the lock nut in the car and play with it.
