Page 44 of 64 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #431
    Arghhhhh! Sorry man!
  2. #432
    I'm sorry Jim.
    Hopefully is just the rear drain line. Those are always a pain.
    JNS Engineering verified
    San Jose, CA
    It's the rear VC. Hopefully the gasket isn't damaged. Should have removed all those brackets before trying to seal it the first time. Turbo isn't even wet. Feed and return are sealed tight and shaft spins freely. Jumped to conclusions after spending so many hours to finish her up.
  4. #434
    Sep 2011
    Kent, United Kingdom (of miserable bastards)
    Ah thankfully it's something simple !!
    Best of luck with the rest if the repairs
  5. #435
    San Jose, CA
    Rear VC gasket was out of the channel toward the inside. Simple to fix and there are no oil leaks now. Metal / metal sound appears to be the AC pulley giving out after sitting for 8 months. Seems to be some internal resistance between the pulley and AC clutch. Probably need a new compressor.
    Also need to do more brake bleeding as the initial bleed had the ABS hydraulic unit off and the rear needs to be bled as well.
    She did get down on all fours and move under her own power a couple of feet forward. Clutch take up point is really close to the floor so I might adjust that too. If anyone has the link to jackhammer's clutch adj video I would appreciate it.
    Also had the ECS lights flashing and was thankful to find the passenger side shock connector unplugged so that was an easy fix.
    Need to get the car to smog before Saturday or I will miss the registration deadline. NorCal3S annual meet is a week from Sat too. It's about 2 hours drive away so I'll need to build confidence to go there.
    Almost forgot, I still have to flash the ECU with the injector size and latencies. Also have to change the fuel pump out which I can do now that the car isn't backed up against the rear wall in the garage.
  6. #436
    Dayton, Ohio
    Sounds like you are just around the corner from having her back
    TREMENDOUS work, sir....
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  7. #437
    SoSoCal verified
    You can put your registration in suspension for like $20 just FYI but then again its good to have a deadline isnt it.
  8. #438
    Glad you're getting it sorted, Jim - I had the rear VC problem, too.
  9. #439
    Adjusting the clutch is easy (other than getting a big guy under the dash). Just loosen the lock nut on the push rod and run the rod in and out to tighten or loosen. Make sure it's bleed very well before you start so it doesn't tighten up later and start slipping. You will probably have to adjust it more than once before you like it. Make sure you leave an inch or two of play in the top and snug the lock nut back up.
    Cliff notes:
    Adjust the rod until you can't push the slave cylinder in by hand then give it a few turns the other way and make sure you can push the slave back in.
    This will give you max travel without closing the fluid return valve when the pedal is up.
  11. The Following User Says Thank You to Toni For This Useful Post:
