Page 64 of 64 FirstFirst ... 1454626364
Results 631 to 634 of 634
Thread: JimVR4 95 Spyder Engine Rebuild
  1. #631
    JNS Engineering verified
    San Jose, CA
    It's me again
    Been trying to sort out a small oil leak. Seemed to be between the TC and bell housing so I pulled the TC and it looks like the output shaft seal has a slow leak. There's no felt as I had lost it somehow and forgot about it when installing. Since the car isn't driven much is it possible the seal is drying out a bit without the felt in there? What would you guys do?
    Not really looking to pull the trans for such a small leak. It was a brand new seal at the rebuild and didn't leak at all in the beginning.
  2. #632
    For what it's worth I replaced that seal with the trans in the car. PITA but I was able to do it. Separated the trans from the engine as much as I could and had to cock it to one side, but then I was able to pulled the seal out and put a new one in. Did I mention it was a royal PITA
    It's me again
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
  3. #633
    San Jose, CA
    Never thought about trying that. I thought the ring gear got in the way but props to you for figuring out a way. I'm thinking maybe get the felt off a new seal and glue it on to mine. I think these seals are design to have a very slow leak and the felt absorbs it and distributes it to keep the seal lubricated since the full fluid level is below the output shaft center.
    Anyway, I could be full of shit and end up pulling the transmission to replace the seal
  4. #634
    Think I even made a thread about it on the other forum
