Long read but worth it.
So as some may know I am working on Courtney's car. Had to replace all the old braided SS lines as they were all leaking like a sieve everywhere. Old lines just not E85 compatible.
So got that all done and also replaced the fuel filter element that was paper with a stainless steel element, replaced the old PTE 1000s injectors with new Deatschwerks 1000s since they would be full of disintegrated fuel hose.
Found NGK copper 9's were installed which are way to cold for a street only car so I installed a set of the Champion race plugs.
His AEM WB sensor was dead so I replaced that with a new one. And configured the AEM for the new battery off set table for the DWs.
First startup an it seems to run not as smooth as I would like but it does have BC 280/280 cams so maybe that is why. I try to drive it a little to see where we are at with the new injectors. It does NOT want to accel smoothly, and low rpm lo load low MPH drive-ability is horrid. Missing, sputtering, no power. I obviously am not going to try loading it up and high rpm with it running like that. So back into the shop.
Feeling like it's got a cylinder out I start testing. Since it is AEM I can turn off injectors. Turning off one at a time cylinders 1, 3, or 5 the car will chug and die. 2, 4, or 6 no change at all. They are not contributing. I can even unp;lug the rear injector harness. No change.
I could pull plug wires for 2/4/6 off the coil pack, no change.
Ok, for 2 days I tear the car apart and put it back together trying to find out why the rear 3 cylinders are almost dead at idle, and cruising. Very rough, low power trying to cruise at slow speeds at low RPM.
With plenum off I can see the injectors firing, Plugs on the ends of the wires to test the entire ing system and the plugs are igniting.
Swapped out injectors twice, PTU, Coil pack, plug wires, plugs, Traced all the wires in the ign and fuel inj system plug to plug and to the AEM and found no breaks. The plenum has been off no lie about 12 times. Even tried my AEM with no change, and his AEM in my car which ran fine.
Checked timing and found he had Fidanza cam gears and surprise...they had slipped like they always do. Rear exh was at +5 degrees instead of -3. Front exh at +3 instead of -3. You can tell where they used to be by the score marks the washers made as hey slipped. Thought I found it. Removed the cam gears and after finding true 0 cause they are mis marked making -1.5 true 0 I Pin/locked them down at +1 -3 as I always suggest and how I run them on my car. Now they can not move unless they sheer the bolts, which they won't.
Still, no change. WTF?
At this point I am pulling my hair out. Last night Vicki says, "Ask Ray, he may have run into this issue." I have always said, I don't know everything, someone else always has an idea or direction you may not have pursued. And sometimes you just need to step back and get a new set of eyes on the issue. And at this point I have no other directions to go.
So I asked Ray Pampena, Told him the whole scenario as I have written above. First thing he asked me straight up was "Does it have BC 280 cams?"
I said, YES!. He said, take them out. Put stock TT cams in it.
He has had this happen 3 out of the 3 times he has tried BC 280 cams in cars. Back bank, dead stumlinb missing at low RPM low load. Back bank just not contributing as it should. Every one fixed by putting in stock cams.
So even though I just had the tbelt off to do the cam gear fix and had put it all back together (i thought I found the problem) Today I pulled is all back apart and swapped in a set of stock TT cams (V/D).
Know What? Purrring like a kitten. In the AEM I can now turn off each injector one by one and each one is contributing and turning just one front bank of doesn't make it die. Every one is equally contributing.
Ray says he has never figured out why the BC280s are doing this but every time stock cams have fixed it. My take is they are probably so far off that is makes the rear valve timing such that they don't contribute.
I ran into BC issues in the past, A set of BC cams would be degreed using a degree wheel and all 4 were so far off from each other in a set it was as if they should all have different cam cards. BC always denied ANYTHING was wrong with their precious cams. We knew different. I used to sell them. I have taken them off our site. I refuse to sell a customer a problem. We are working on a solution.
Thank you Ray! You rock. All of the parts, wiring checking, running in circles. All because shitty cams.
-Chris
. I know he does have stock 74 camgears so I am sure his cams are not timed to the spec.
VD Dynojet shows 177 lbft @ 1500, 200 @ 1936, 250 @ 2864, & 300 @ 3142
